Hello, I have a DVD which is region 3.My dvd player(sony DVPNC875v play only region 1)won't play that so I have copied through 1 click dvd, DVD Fab Platinum, DVD Decrypted, I have copied the same movie several types, but no use, when I put it in my player it says can't play the disk due to Region settings. what could be wrong ? while coping I have checked remove protection in all the software’s I used
Some players must have a region setting that is readable from the disc. Set the region code on the disc to match your player.
OR it could be a PAL disc and that message you are seeing is displayed for both a region mismatch and a format mismatch. -
The default setting when ripping with DVDDecrypter is to remove region protection. You can however force it to set RPC to anything you wish, if your player wont play RPC free discs (unlikely).
You might however (very likely) be facing a TV system problem, where you have a NTSC only player that refuses to play a PAL disc?
/Mats
Remove Blu-Ray Region
By djhansel in forum Blu-ray RippingReplies: 13Last Post: 9th Dec 2010, 17:51 -
VirtualDub - Remove Region plug-in problem
By fazerking in forum Newbie / General discussionsReplies: 6Last Post: 19th Apr 2010, 13:30 -
remove region filter
By atomicock in forum EditingReplies: 5Last Post: 5th Nov 2009, 07:36 -
Can't remove region restriction using DVD Shrink. Work-arounds?
By csloane@nwnexus.com in forum Newbie / General discussionsReplies: 2Last Post: 7th Apr 2008, 17:04 -
Remove region code?
By hiimbored in forum DVD RippingReplies: 12Last Post: 6th Jun 2007, 23:55
