  1. I used DVD Decrypter 3.5.4.0 to rip a VOB file from a dvd that is unprotected. I want to edit the VOB to correct the color and brightness level, but the time is out of order.
    For example, if I play the ripped VOB file in PowerDVD 6, the time counts normally until 10:35. Then it resets back to zero, however the video continues to play normally. It does this at other points in the VOB as well. The same thing also happens if I try to play the VOB directly off the DVD from the Video_TS folder.
    However, if I play the DVD in PowerDVD and select the menu option that corresponds to the VOB in question, the time counts normally.
    What is going on?
  2. I should add that because of the time problem, every program I've tried to edit the video will not work. It only sees the video up to the point where the time resets. I've tried Tmpgenc, Premier and Canopus.
  3. Member yoda313's Avatar
    Jun 2004
    The Animus
    Rerip it with another ripper like dvdfabdecrypter and see if it still happens.
