I have some AVIs I want to put on one DVD. I've converted them to MPEG. The audio is in sync in both sets of files.
I then used TMPGenc Author to make the DVD with each of the files as a different chapter. When playing the DVD, the audio is out of sync on every chapter.
(as an aside.. If I make a VCD with any one of the files, the audio is in sync fine)
I guess the next step is to strip the audio off with Virtual Dub and then use those audio files in TMPGenc? It's quite a process - is it likely the audio will then match up on the final DVD?
EDIT - it won't let me do it anyway.. have stripped off the WAV, but TMPGenc says DVDs can only use Dolby AC-3, MPEG1 Layer 2 or Linear PCM.
Help!
When you stripped off the wav, did you use full processing mode and set the compression to uncompressed PCM ? Wav, like AVI, is a container format. The actually encoding inside it can vary. I suspect you have a wav file that has mp3 encoding in it.
Read my blog here.
The issue is probably with you having each track as a separate chapter and you are simply joining together and adding chapter points. Try setting it up with 'Add new Track' (on the left) and then when done, add a menu to then select each track. Should be ok.
VDub only renames the audio to wav-it is not a TRUE wav unless it ACTUALLY contained wav as audio. If it were mp3 in your source file then simply rename the audio with .mp3 extension etc. You could use ffmpeggui to convert to AC3 if you dont have plug-in for TDA. And TDA will take LPCM (uncompressed wav) but will be a bigger file size though.
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 22:09 -
AVSTODVD avi to dvd audio sync problem
By stem300 in forum Authoring (DVD)Replies: 6Last Post: 26th Dec 2011, 14:52 -
Mkv Audio sync problem converting to DVD
By yudopplyr in forum Video ConversionReplies: 14Last Post: 10th Dec 2011, 15:55 -
DVD Flick audio sync problem?
By neo*2 in forum Video ConversionReplies: 4Last Post: 6th Sep 2009, 14:51 -
HD dvd conversion, audio sync problem...
By BigJeebz in forum Video ConversionReplies: 6Last Post: 5th Aug 2008, 22:52
