Just wondering what hardware and cables are needed to output from a PC to TV? Do I just need a video out card and some rca cables? What would a PC to TV setup run me?
Tom
Check your graphics card. If it only a year or two old there is a good chance it will have an s-video output on it. Just plug that into your TV or AV-amp, hook up the sound and you are set to go. Otherwise, your options are either a VGA to composite converter, or replace the graphics card with one that has video out (most do). I occassionally hook up a laptop to my amp with a single s-video cable, and a 3.5mm stereo phono jack to stereo RCAs cable. works a treat.
Read my blog here.
If it turns out that you have to buy something in order to get what is on your pc to your tv then I suggest the Hauppauge MediaMVP. Ebay is selling them for around $60 plus shipping and Newegg for $86. This unit plays video, music and stills via a LAN cable.
Just a thought!bits
Cheapest/easiest software to create an electronic personnel action form?
By wetcamelfood in forum ComputerReplies: 2Last Post: 15th Jan 2012, 08:58 -
Best/Easiest/Cheapest tool for VOB to AVI
By andredanton in forum MacReplies: 4Last Post: 26th Sep 2008, 16:44 -
Whats the cheapest way to build my dvd collection?
By ryangarfield in forum Off topicReplies: 15Last Post: 12th Jan 2008, 18:20 -
Whats the cheapest, easiest way to make a webcast on my site?
By nato17 in forum Newbie / General discussionsReplies: 0Last Post: 12th Aug 2007, 19:06 -
DVD to PSP, whats the easiest way to do it?
By Nick1982 in forum Newbie / General discussionsReplies: 0Last Post: 8th Jul 2007, 07:45
