Hello,
I have friend who just received a DVD either recorded in or purchased in England. I know there are region encoding that are not compatible, such as the US and Canada use NTSC and most of Eurpoe uses PAL.
Assuming this is why he can't play the DVD from abroad in any of his players here in the US, is there anything I can do for him, such as a conversion?
I'm not even sure if his DVDs are PAL. I have AVIcodec from a couple years ago, will that tell me? If not, is there a utility that will help me identify the codecs on his DVDs?
Thanks for your time.
pmc
Originally Posted by pbmc59
Purchased (commercial) DVD's will have a region coding, recorded DVD's will not. All consumer DVD's meant for the UK market will be PAL.
Region coding and PAL/NTSC is not the same thing.
In order to play them in the US you would need a region free dvd player as well as one that does PAL to NTSC coversion."Art is making something out of nothing and selling it." - Frank Zappa -
Yeah and also remember that some TVs will do pal to NTSC conversion too..actually you DONT need a region free player .. all players will allow you to change the region four times .. but most can be made region free very easily..
You should be able to view the content on a PC if you use dvddecrypter to place all the assets on your hard drive.Corned beef is now made to a higher standard than at any time in history.
What?Originally Posted by RabidDog
You are confusing a computer DVD drive or burner with a standalone DVD player....there are MANY players that cannot be hacked region free, changed to a different region and/or convert between PAL/NTSC and vice versa.Originally Posted by RabidDog -
Region 2 NTSC isn't uncommon even though PAL is the standard for the UK. But, PAL may be the standard for the UK and Europe but Japan is in Region 2 as well and they use NTSC over there. For this reason all Region 2 or multi Region DVD players will happily play both formats. You can usually find a setting in the menu to set what format is output to the TV. Usually you get a choice between PAL, NTSC or Auto. In Auto mode it will output what is being played, in the others it will output what you have selected no matter what format the disc you are playing is.
What format to use to burn video to DVD to be played in the UK (England)?
By jubbilee in forum Newbie / General discussionsReplies: 2Last Post: 1st Sep 2011, 02:21 -
Obama bought the President of England a bunch of DVD that are region 1 LOL
By vatkat234 in forum Off topicReplies: 4Last Post: 20th Mar 2009, 20:15 -
Canuck DVD player to England...HELP!!??
By Lonsman in forum DVD & Blu-ray PlayersReplies: 10Last Post: 1st May 2008, 18:34 -
Taking a American purchased Desktop to England
By Faustus in forum ComputerReplies: 11Last Post: 26th Aug 2007, 14:28 -
VHS tape recorded in England
By lolabragg in forum Newbie / General discussionsReplies: 2Last Post: 17th Jun 2007, 22:05
