How do I convert a mpg extension mpeg2 file to dvd?
I don't want to re-encode the video.
This is a block of text that can be added to posts you make. There is a 255 character limit
You need to "author" your mpeg then burn. TMPGEnc DVD Author will do that, it will also tell you if your mpeg is DVD compliant. You cannot burn any old mpeg2 to dvd as there are restrictions. Check "what is DVD" on the top left of this page for more info. You can check the authoring section for more authoring options.
"Art is making something out of nothing and selling it." - Frank Zappa -
How can I burn it with Nero?
its .mpg extension. I want to use my tv to watch it.This is a block of text that can be added to posts you make. There is a 255 character limit -
Did you not read the reply ?
Unless your settop DVD player can play raw MPEG, then you must author it. To be able to author it, it must meet DVD specifications first. The process of authoring converts the MPG file into IFO, BUP and VOB files inside a VIDEO_TS folder, which is what most DVD players need to be able to play it.
Check your MPG file with the latest GSpot Beta (2.52) and compare this to https://www.videohelp.com/dvd . If the file is DVD-compliant then you can go forth and author. If not, then you need to re-encode it so it is, or apply some fancy stuff like patching the headers so that your authoring software thinks it is.If in doubt, Google it. -
Is there a program that can do it quick. I don't care about menus or anything like that.
TMPGenc DVD Author will do it for you provided the Mpeg meets dvd requirements ... if it doesn't you can re-encode it with TMPGenc Xpress3.0 ... both programs are available as a free 14 day trial here http://www.pegasys-inc.com/en/index.html
How to import MPEG2-TS to Adobe Premier? How to convert MPEG2-TS to MKV? :)
By farzad in forum EditingReplies: 19Last Post: 29th Feb 2012, 17:25 -
mpeg2 ts file convert to mkv or mpeg2 ts......change only video bitrate...
By jrblack in forum Video ConversionReplies: 4Last Post: 24th Jan 2011, 19:45 -
How do I convert .ts to .mpeg2?
By Zippity in forum Video Streaming DownloadingReplies: 1Last Post: 29th Mar 2010, 20:43 -
Wish to convert from .TS to compliant MPEG2
By gabier in forum Video ConversionReplies: 28Last Post: 9th Jul 2008, 04:34 -
convert hd pal mpeg2 file to hd ntsc mpeg2 file
By gearo in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 5th Jun 2008, 02:12
