hi imtrying to make one big .vob file with DVD decrypter out of a PAL DVD and when it decryptes theres no audio anymore. Maybe it decrypters to a different, weirder codec. does anyone know what the problem might be?
Results 1 to 11 of 11
Maybe you don't have the AC3 filter installed?
Unless you went into Stream Processing and did something funny, the audio is still in there. -
File Mode ? IFO mode ?
These might help:
http://members.dodo.com.au/~jimmalenko/Smartripper.htm
http://members.dodo.com.au/~jimmalenko/FileDVDDecrypterV3220.htmIf in doubt, Google it. -
yeh he needs ac3 filter or ac3 decompressor.
thats my 2 centsLifeStudies 1.01 - The Angle Of The Dangle Is Indirectly Proportionate To The Heat Of The Beat,Provided The Mass Of The Ass Is Constant. -
ok i got ac3 filter and i have no idea what to do with it. By the way i think i found out that i need to split my .vob files into video and audio before i turn it into mpeg which is what i was trying to do. Then i got an m2v and a .ac3 and when i tryed to load the ac3 for the audio to put it into mpeg an error came up and said it was unsupported so i guess this is where ac3 filter would come into play?
Well, when you play the AC3, can you hear it now? If not, then install the AC3 Filter.
ok ive separated my audio and video (m2v and ac3) but i changed the ac3 to a wav and the only way i can combine then is to mkae it into a mpeg-2 but i want a mpeg-1 so i can play it on my dvd player. i get an error that says "current system stream format can not include Dolby Digital stream". How to i combine them to make a mpeg-1!?
DVD Decrypting Question?
By daz1976 in forum DVD RippingReplies: 5Last Post: 14th Jan 2010, 16:44 -
decrypting a dvd with MTR 2.6.6
By andyx181x in forum MacReplies: 11Last Post: 2nd Dec 2007, 10:05 -
Errors decrypting dvd
By Beaker14 in forum Newbie / General discussionsReplies: 2Last Post: 31st Oct 2007, 11:59 -
Decrypting Software
By csaplot in forum Video ConversionReplies: 1Last Post: 22nd Jul 2007, 10:54 -
DVD Decrypter only decrypting 46 minutes of DVDs
By morphjk in forum DVD RippingReplies: 5Last Post: 21st Jul 2007, 04:26
