I have been using DVD Decrypter and DVD Shrink for awhile now. The process I do is I first decrypt and put on hard drive with decrypter and then shrink and burn using Shrink. I have had no problems up until recently. Here is what happened. I downloaded and installed the new Musicmatch Jukebox 10 software, I bought the upgrade for musicmatch and upgraded it as well. Now when I use DVD Shrink I get the following gibberish 1% into the burn process....if anyone can decipher this gibberish it would be greatly appreciated...just so you know I have uninstalled both musicmatch and dvd shrink then reinstalled musicmatch first then shrink and still have the problems and this error message. Thank you all so much for the help you can provide......Denise
1A20-0218-0370-1725-8155-4331*
Windows XP 5.1
IA32
WinAspi: File 'Wnaspi32.dll': Ver=4.60 (1021), size=45056 bytes, created 9/10/1999 8:06:00 AM
ahead WinASPI: File 'C:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.68, size=160016 bytes, created 7/22/2004 6:33:44 PM
Nero API version: 6.3.1.26
Using interface version: 6.3.1.4
Installed in: C:\Program Files\Ahead\Nero\
Application: ahead\Nero - Burning Rom
Recorder: <LITE-ON DVDRW SOHW-1673S>Version: JS02 - HA 1 TA 0 - 6.3.1.26
Adapter driver: <atapi> HA 1
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ATAPI
=== Scsi-Device-Map ===
DiskPeripheral : MAXTOR 6L080J4 atapi Port 0 ID 0 DMA: On
DiskPeripheral : WDC WD1200BB-00CAA1 atapi Port 0 ID 1 DMA: On
CdRomPeripheral : LITE-ON DVDRW SOHW-1673S atapi Port 1 ID 0 DMA: On
CdRomPeripheral : SAMSUNG DVD-ROM SD-616T atapi Port 1 ID 1 DMA: On
=== CDRom-Device-Map ===
LITE-ON DVDRW SOHW-1673S E: CDRom0
SAMSUNG DVD-ROM SD-616T F: CDRom1
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 74448896 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 510MB (523056kB)
Free physical memory: 103MB (106380kB)
Memory in use : 79 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
28.10.2005
NeroAPI
12:37:19 PM #1 Phase 112 File APIProgress.cpp, Line 273
DVD-Video files reallocation started
12:37:19 PM #2 Phase 114 File APIProgress.cpp, Line 273
DVD-Video files reallocation completed (no file modified)
12:37:19 PM #3 Phase 111 File APIProgress.cpp, Line 273
DVD-Video files sorted
12:37:20 PM #4 Text 0 File Reader.cpp, Line 126
Reader running
12:37:20 PM #5 Text 0 File AudioCompilationImpl.cpp, Line 817
DRM: StartDrmRecording(RealRec:1, ImageRec:0, Copies:1)
DRM: Beginning burn process.
12:37:20 PM #6 Text 0 File Writer.cpp, Line 124
Writer LITE-ON DVDRW SOHW-1673S running
12:37:20 PM #7 ISO9660GEN -11 File geniso.cpp, Line 3899
First writeable address = 0 (0x00000000)
12:37:21 PM #8 ISO9660GEN -11 File geniso.cpp, Line 3899
12:37:21 PM #9 Text 0 File Burncd.cpp, Line 3152
Turn on Disc-At-Once, using DVD media
12:37:21 PM #10 Text 0 File DlgWaitCD.cpp, Line 247
Last possible write address on media: 2298495 (510:46.45, 4489MB)
Last address to be written: 2286175 (508:02.25, 4465MB)
12:37:21 PM #11 Text 0 File DlgWaitCD.cpp, Line 259
Write in overburning mode: NO
12:37:21 PM #12 Text 0 File DlgWaitCD.cpp, Line 2162
Recorder: LITE-ON DVDRW SOHW-1673S, Media type: DVD-R
Disc Manufacturer: CMC MA - G. AE1
Disc Application Code: 64, Disc Physical Code: 193
12:37:21 PM #13 Text 0 File DlgWaitCD.cpp, Line 420
>>> Protocol of DlgWaitCD activities: <<<
12:37:21 PM #14 Text 0 File ThreadedTransferInterface.cpp, Line 813
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 (CTransferItem)
2 indices, index0 (150) not provided
original disc pos #0 + 2286176 (2286176) = #2286176/508:2.26
relocatable, disc pos for caching/writing not required/required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2286176 blocks [LITE-ON DVDRW SOHW-1673S]
12:37:21 PM #15 Text 0 File ThreadedTransferInterface.cpp, Line 984
Prepare recorder [LITE-ON DVDRW SOHW-1673S] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4682088448, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_RecDep_|_CtrlAdr_
0 | lead-in | 0 | 0x00 | 0x41
0 | 1 | 0 | 0x00 | 0x41
0 | 1 | 1 | 0x00 | 0x41
2286176 | lead-out | 1 | 0x00 | 0x41
12:37:22 PM #16 Phase 24 File APIProgress.cpp, Line 273
Caching of files started
12:37:22 PM #17 Text 0 File Burncd.cpp, Line 4163
Cache writing successful.
12:37:22 PM #18 Phase 25 File APIProgress.cpp, Line 273
Caching of files completed
12:37:22 PM #19 Phase 36 File APIProgress.cpp, Line 273
Burn process started at 8x (11,080 KB/s)
12:37:23 PM #20 Text 0 File ThreadedTransferInterface.cpp, Line 2344
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
12:37:23 PM #21 Text 0 File DVDR.cpp, Line 2011
Recording mode: Sequential Recording Mode
12:37:23 PM #22 Text 0 File Mmc.cpp, Line 20794
Set BUFE: supported -> ON , SMART-BURN : OFF
12:37:23 PM #23 Text 0 File DVDR.cpp, Line 2152
Start write address at LBA 0
DVD high compatibility mode: Yes
12:37:23 PM #24 Text 0 File Cdrdrv.cpp, Line 8228
---- DVD Structure: Physical Format Information (00h) ----
Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD-R (2), Part Version: 5
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 0 h
End Sector Number in Layer 0: 0 h
Data in Burst Cutting Area (BCA) does not exist
Start sector number of the current Border-Out: 0 h
Start sector number of the next Border-In: 0 h
Media Specific [16..63]:
00 30 00 10 20 00 00 00 - 00 00 00 00 00 00 00 00 .0..............
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
12:38:26 PM #25 Text 0 File Cdrdrv.cpp, Line 1297
12:38:26.906 - LITE-ON DVDRW SOHW-1673S\H1 T0 : Queue again later
12:40:56 PM #26 SCSI -1046 File Cdrdrv.cpp, Line 1445
SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x00CA0000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x02 (KEY_NOT_READY)
Sense Code: 0x30
Sense Qual: 0x05
CDB Data: 0x2A 0x00 0x00 0x00 0x48 0x80 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x02 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x30 0x05
12:40:56 PM #27 CDR -1046 File Writer.cpp, Line 304
Illegal disc
12:40:56 PM #28 Text 0 File ThreadedTransfer.cpp, Line 229
all writers idle, stopping conversion
12:40:56 PM #29 Text 0 File ThreadedTransfer.cpp, Line 223
conversion idle, stopping reader
12:40:56 PM #30 Text 0 File DVDR.cpp, Line 2394
EndDAO: Last written address was 18559
12:40:56 PM #31 Phase 38 File APIProgress.cpp, Line 273
Burn process failed at 8x (11,080 KB/s)
12:40:56 PM #32 Text 0 File AudioCompilationImpl.cpp, Line 828
DRM: DRM burn session terminated.
12:40:56 PM #33 Text 0 File AudioCompilationImpl.cpp, Line 857
DRM: Closing entire DRM handling. Bye.
Existing drivers:
File 'Drivers\ADPU160M.SYS': Ver=v3.60a (Lab01_N(johnstra).010529-2218), size=101888 bytes, created 8/17/2001 3:07:32 PM
File 'Drivers\CDRALW2K.SYS': Ver=5.2.0.91, size=23724 bytes, created 7/29/2003 2:50:48 PM
File 'Drivers\ASPI32.SYS': Ver=4.60 (1021), size=25244 bytes, created 9/10/1999 8:06:00 AM
File 'Drivers\ASPIXNT.SYS': Ver=1.07.00, size=14208 bytes, created 2/21/2001 3:51:04 PM
File 'WNASPINT.DLL': Ver=V1.17, size=55808 bytes, created 9/19/2002 1:00:00 AM
File 'Drivers\PXHELP20.SYS': Ver=2.03.18a, size=20576 bytes, created 5/10/2005 4:04:10 PM (Prassi/Veritas driver for win 2K)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
1st thing is edit your Nero log posting and remove your registration code (first line). I guess what I would do is download Nero CleanTool and uninstall Nero and then download the latest Nero 6 (6.6.0.16) and install it. Nero 6 probably got corrupted.
http://www.nero.com//nero6/eng/Nero_6_CleanTool.html
http://www.nero.com//nero6/eng/nero-up.php -
Too tools for newbies :
Installwatch , and regsnap
Before installing any program , do a reg snapshot
Next , fire install watcher
Run actual program you are installing
When installed , save install watcher info
Do a second snapshot of reg , save both snapshots
This will make tracking the problem down alot easier .
DVD Shrink Problem?
By LCE in forum Newbie / General discussionsReplies: 9Last Post: 15th Jan 2010, 07:38 -
Problem using DVD shrink 3.2
By aldago in forum Newbie / General discussionsReplies: 12Last Post: 13th Feb 2009, 20:28 -
DVD Shrink- Reauthoring Problem
By MPO in forum Newbie / General discussionsReplies: 2Last Post: 24th Jan 2009, 11:42 -
Dvd Shrink Problem
By letty in forum DVD RippingReplies: 5Last Post: 23rd May 2008, 08:09 -
DVD Shrink problem
By lapetite_66 in forum Newbie / General discussionsReplies: 27Last Post: 10th May 2007, 10:21
