I have an AVI file 45 minutes long in Premiere. I want to get it to CD with tracks to be able to listen to it in my car. I tried exporting it to Audicity then to Nero to burn but it was speeded up when I listened to it in Nero before I burned it. The i tried straight to Nero and it was speeded up also. How can I get this file to CD with tracks?
Results 1 to 14 of 14
Make sure the audio is 44100hz 16bit....if it is not it needs to be.
will that give me the ability to divide the file into, say, 4 minute tracks?
Also what do you guys think of Sony Forge or something like that -
Originally Posted by Cornucopia
1. Download the CDWave application
2. Install the CDWave application
3. Run the CDWave application
4. Load(Open) the WAVE file from within the CDWave application
That's all there is to it.
If CDWave isn't seeing the file (after browsing for it), maybe you didn't export from Premiere correctly. I just did a trial one before posting to make sure all these steps are correct. No Problem...
Scott -
Originally Posted by Havalilsi
1) Slowing down and/or correcting the .wav file so that it is 44.1 16bit.
2) Once that is completed....find software like CDWave that can split/divide the audio into individual songs.
CDWave can do both by the way....divide and export as the correct 44.1 16bit. -
Sonic Foundry Sound Forge will do it too ... but its a bit pricey
Use Feurio! track editor - it's free to try. This program does just about anything from splitting tracks, to volume adjustment, to index markers...
http://www.feurio.de
Though it probably has to be in 44.1kHz/16-bit .WAV form first. -
Originally Posted by psx_pirate
Audacity can put label markers through your wav file & export separate tracks; then just load into your burning software (just like CDWave). It will upsample too. Any hiss you can possibly cut out with the built-in NR or FFT filters. You can also speed up or slow down.
Video with L/R tracks to DVD with 2 channel audio tracks
By Downloader in forum Authoring (DVD)Replies: 2Last Post: 22nd Aug 2010, 01:56 -
Audio tracks
By siluet in forum Newbie / General discussionsReplies: 2Last Post: 17th Sep 2009, 21:07 -
Ripping tracks
By hedcha in forum DVD RippingReplies: 5Last Post: 12th May 2008, 11:40 -
Need advice on making dvd copies and making ISO files please.Thanks!
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 1Last Post: 17th Jan 2008, 12:03 -
Joining tracks?
By c5vetman in forum Authoring (DVD)Replies: 1Last Post: 19th Nov 2007, 14:18
