I like to have the best looking picture with smallest size possible for email attachment. preferred size is 640x480 pixel. What program or else gives me that best ratio.
What these guys just said, plus one possible caveat -- jpg compression is almost always your best bet but if your picture contains any lettering or text (like signs, fr'instance), jpg can make text characters look pretty ragged.
The only way to tell, is by saving at different compression ratios as a jpg, or you might try gif or bmp if text clarity is the most critical thing.
If you don't already have some kind of image editing program, take a look at Irfanview (www.irfanview.com)-- it's free, it's darn good, and you can play around with different formats and image sizes and see what looks better or worse to you. Also no matter what you end up with, it's always a good idea to check with your recipient ahead of time to make sure they can receive whatever attachment you end up sending, as well as get a max on file size.
Test attachment
By intracube in forum TestReplies: 2Last Post: 28th Dec 2011, 09:35 -
Forum attachment storage limits (MB)
By intracube in forum FeedbackReplies: 4Last Post: 28th Sep 2011, 15:58 -
Solved: How to email high quality printable doc with English and Chinese
By jimdagys in forum ComputerReplies: 5Last Post: 3rd Oct 2008, 14:25 -
auto-play a .wmv attachment in an email?
By mikejaz2 in forum ComputerReplies: 3Last Post: 24th Mar 2008, 14:28 -
what best file type to send as email attachment
By philwright in forum Newbie / General discussionsReplies: 5Last Post: 5th Feb 2008, 14:18
