I am having problems backing up the movie Bewitched it is a sony movie so Im guessing its got that sony protection on I just wanna know is there a program I can use to get rid of the protection so I can copy the menu's and not just the movie
Thanks for your help!!
Results 1 to 19 of 19
DVD FabDecrypter, then use DVD Shrink in file mode. I had no problems, however, reading other forums, many people are getting results like you using a variety of other back-up tools.
How do you mean in file mode???
Like backing it on to hard drive with dvd fab decrypter and then shrinking it from file I tried that already it didnt work -
DVD Shrink, OPen Disk or Open Files. If you were able to get the movie to your hard drive using DVD Fab Decrypter. There should be no reason Shrink would not compress and burn for you. What are the specific errors or problems you are having using these tools?
I backed my daughters copy up but had to use DVD_RB because it's mising ifo's. If you look at it after you rip it some ifo files are missing. Might be some kind of new protection.
you could rip with dvd decrypter,copy the errored fles,and make your own .psl,then reload and rerip.
or use anydvd when ripping with decrypter.
if you use dvd2one to reduce it to 1 dvdr,then you can always delete the strange cells,that may have 0mg size or strange sized ones.
better yet,take it back to the shop and smack them round the head with it,as that crap doenst even deserve to be on disc.will ferret is a twat,a total not funny twat.<--thats IMO,rant over.LifeStudies 1.01 - The Angle Of The Dangle Is Indirectly Proportionate To The Heat Of The Beat,Provided The Mass Of The Ass Is Constant. -
Ok when I back it up onto hard drive with DVD Fab Decrypter it works fine from the hard drive but as soon as it goes on DVD-R it start disc then just STOPS i dont know how to use dvd2one the trial will only let me do stuff to the movie not the whole disc HELP HELP HELP
Someone start a new,official topic, IT'S TUESDAY, I CAN'T BACKUP THIS DVD.....
Dvd fabdecrypter to get it on the HD. Then dvdshrink to open it, and strip the extras . Then dvddecrypter to burn. I KNOW this works.
A good divorce beats a bad marriage.
Now I have two anniversaries I celebrate! -
I just backed it up yesterday, but I did it manually with DvD Decrypter in "IFO" mode.
This does use a different type of copy protection. They usually insert bogus Vobs, but this one uses a corrupt AC3 header. The copy protection ends up being in the Audio rather than the Video. The process is a little complicated, but it can be done.I stand up next a mountain and chop it down with the ledge of my hand........ I'm a Voodoo child.... Jimi Hendrix, -
I had already backed up my copy of Bewitched (the way I wanted it) using DvdFab Decrypter, VobBlanker, and PgcEdit, but I found a premade PSL2 file on the Digital-Digest forum (here), and tried it out on my original disk. DvdDecrypter ripped it perfectly using the PSL2 file.
I also had a problem backing up bewitched.
After many attempts I used this procedure.
Dvdfabdecrypter to backup the disk to harddrive.
Copy the main vob's to a seperate folder.
Rename the vob's to VTS_01_1, 2, 3 etc.
Use ifoedit to create new ifo's and bup's.
Worked for me.
Hope this is of help to someone
Kiki -
Everyone saying DVD Shrink is not allowing the files to be opened after ripping with DVDFab Decrypter, are you using the latest version ?
I have seen many people say yes then find out they did NOT have the latest version of a certain software
Because i had the same problem with Lords of Dogtown before it was updated. I had to also run them through VobBlanker after getting them to the HDD with the last version of DVDFab Decrypter.
I tried DVD Decrypter on Bewitched, i got the same error as with LOD,
I ripped it with DVDFab Decrypter, opened in DVD Shrink no problem.
Did a full disc and a movie only and they both played fine after burning to a dvdr 8)
Incorrect,Originally Posted by jdizzy40
before fengtao updated DVDFab Decrypter it was doing exactly that with Lords Of Dogtown, ripping it to the HDD yet DVD Shrink could not open it.
--->Lords of Dogtown<---
As stated above, i backed it up perfectly with only the latest DVDFab Decrypter & DVD Shrink.Originally Posted by studmonkey76
And i'm sure it's the same protection they used on Lords of Dogtown which was already taken care of with the latest DVDFab Decrypter... -
ok i know someone has probably all ready said this said this but i just used
anydvd 5.5.1.1. and dvd shrink and made a perfect copy no hassle at all.
tryit it works on xp sp2 2.4 gig 1gig ram computer with msi writer dl. -
Oh fer F#$@'s sake!!!!!!!!!!Originally Posted by anxsdf3
Originally Posted by NoahtuckI have NEVER had anydvd or any of that other "Pay" crap on my PC to back up a dvd...Originally Posted by Noahtuck
But then i've done alot of things people have said could not be done
Where the hell is Gurm when ya need him
Backing up files
By didikai in forum Newbie / General discussionsReplies: 19Last Post: 3rd Nov 2011, 08:17 -
Backing up HD DVD
By captainzog in forum Newbie / General discussionsReplies: 13Last Post: 21st Oct 2011, 09:49 -
Backing up files
By Deathstrike in forum ComputerReplies: 4Last Post: 5th Jul 2010, 21:16 -
Backing up old VHS
By ClarkWGriswold in forum Video ConversionReplies: 5Last Post: 31st Dec 2009, 13:33 -
Backing up a DVD
By kschwi in forum DVD RippingReplies: 19Last Post: 29th Nov 2009, 09:15
