I have downloaded DTS audio cds it comes in a rar compressed wav files
As I have understood these are 5.1 channels audio tracks
I tried to play them on my PC and I get noise only.
I tried to burn them with nero as Data Cds and play them with my
Divx player which contains integrated AC3 decoder and is connected to
a 5.1 speaker system but I've got also only noise.
Results 1 to 17 of 17
You need to burn them as audio CDs and play them back through a player tha sends a digital audio signal to an amp that decodes DTS. If you can't get a digital signal to a DTS decoder you will get pink noise, which may damage your speaker if it is too loud.
AC3 is Dolby Digital, and is not compatible with DTS. If you have power DVD or similar installed on your PC you should be able to decode the DTS signal.Read my blog here.
I am having a problem playing audio CD with DTS. I've burned the wav file and my DVD player will not play them. In fact, it ejects the disc.
What am I doing wrong?2 DVD, or not 2 DVD, that is the question. -
How are you burning? you should create an audio cd and not just burn the wav files on the cd as data cd.
I did create an audio cd with Nero, and included the wav file. Am I missing something?
Actually, I just realized that I have a bigger problem. My Pioneer DV-333 will not play any CDs at all. It just ejects the disc after trying to load them.
Both burned audio cdrs and commercial cds? Then I guess you have found the problem....try the dtscd on another dvd.
Run it through DTSparser, and you'll probably be able to play it on your PC
http://hypercubemx.free.fr/html/dtsparser.html -
cim - You joined the forums over 4 years ago and according to your profile you have posted over 80 times here. What on earth possessed you to make you think that digging up an old post over 2 years old and adding to it was an appropriate course of action? Please make a new post in the future instead of doing what is called "grave digging" in resurrecting ancient posts. There was absolutely no need for this. You are very lucky I am not a moderator and that Baldrick has decided to have mercy on you and not do anything about your post. I would lock your post if I was administrator and force you to make a new one.
The first thing you need to do is to be able to play the files on your PC to be sure that they are actually OK and not garbage. PowerDVD and WinDVD are possible solutions. I know nothing about DTSparser, but surely it would work OK. If the files can be played OK on your PC so you know they are good, then I would look into questions of media. For example, your DVD player may not like your media brand. Try the discs on a friend's DVD player and see if they play OK or load them on a PC and see if your PC tries to play them. You need to determine, in order:
1) Are the files OK? If not, that's your problem.
If the files are OK, then
2) Can other devices (PC, other DVD players) play the discs correctly? If not, perhaps something went wrong in your burn. If they play OK but not on your Pioneer then
3) Maybe you need to use another brand of disc. -
how can i burn Audio Cd which will play in my car CD playerOriginally Posted by jman98
I'm not going to answer because either your post is a joke (not funny, by the way) or you are a a complete moron to have included my entire rant against digging up old posts in a thread that was almost 1 year old since the last post. I would advise others in the forums to not reply to this either.Originally Posted by a05014886
Hi,
I already burned the DTS Files , and actualy I can play it with my DVD Player. But I wanto to author it as DVD Files, so I would play it with my MediaGate Streamer.
Any Help will be wellcome.
Antonio Souza -
GunS1inger, altsouza
i tried all means and generated audio CD with DTS tracks as mentioned above, but still i get noise through my DTS signal on the receiver lights up but only noise.
Procedure as follows
Input files : 48 KHz ac3 (5.1) files
Used BeSure + BeSweet +Surcode 1.0.20 (Surcode 1.0.9 crack doesnt work) output to PCM WAv files and burnt a Audio CD- No luck
Used Headac3he to resample the files to 44.1KHz and then convert them to WAV files and then burnt to Audio CD - noluck
Any ideas here please
Zorro -
Sorry for digging this up so long after the original post, but I've been through this a lot lately. My answer in short was:
Demux .DTS files with Tranzcode
resample to 44.1khz with audio commander or similar
Remux and encode with Surcode to wav files
burn with Nero.
Works fine for me.
The issue I had is that most of the DTS files I was using were meant for a DVD-A output. they are 48Khz and can't be recorded using redbook audio CD authoring tools. I haven't found a faster or more convenient way to do this yet...it takes a while to re-encode the files, since you have to do them one at a time and you need to properly place the 6 channels...but it works for the ones I cared about about.
here is the long answer in link form:
http://pr0jects.blogspot.com/
Hope that helps.
The other alternative is to author a DVD-A with the DTS files, which I'm not fond of.
Burn AVCHD to DVD5 with DTS High Resolution audio?
By nateo200 in forum Authoring (Blu-ray)Replies: 10Last Post: 24th Jun 2012, 06:21 -
I can't play back .m2ts files with DTS audio
By Quadcam in forum Blu-ray RippingReplies: 3Last Post: 24th Nov 2011, 17:31 -
help gettinng .m2ts with dts to play on ps3 with the dts intact. got close
By jayjay139 in forum Blu-ray RippingReplies: 0Last Post: 12th Mar 2010, 13:10 -
Problem trying to play DTS audio
By seven_deuce offsuit in forum AudioReplies: 14Last Post: 5th May 2008, 00:49 -
DVD Player wont play DTS 6Ch, can i change Audio?
By snadge in forum Newbie / General discussionsReplies: 31Last Post: 16th Jan 2008, 07:12
