i am having a prolem when i try to start all i get is the following if any one can help plz![]()
Version: SVCD2DVD 2.0
Build: 2.0.2070.34697
Type: System.NullReferenceException
Source: SVCD2DVD
Message: Object reference not set to an instance of an object.
InnerException:
StackTrace: at x3284ccece41ee22b.x210ff09a2516b1a7.x0507e45eec4e9 097(Object xe0292b9ed559da7d, EventArgs xfbf34718e704c6bc)
I would update to the latest build... that should sort it out.
proplem with converting to .mkv
By vbd in forum Video ConversionReplies: 1Last Post: 23rd Apr 2010, 04:22 -
Proplem with mapping menu and title buttons using DVDit PRO 6
By jakewoodblues in forum Authoring (DVD)Replies: 0Last Post: 14th Apr 2010, 17:56 -
Starting a new project
By jmofosho in forum RestorationReplies: 2Last Post: 15th Dec 2009, 15:48 -
DVD-VHS Recorder Proplem with Recording
By mactek in forum DVD & Blu-ray PlayersReplies: 4Last Post: 7th Nov 2008, 16:02 -
starting over-codecs
By uglijimus in forum Video ConversionReplies: 5Last Post: 14th Jul 2007, 09:57
sorted worked a treat thanks for the help m8 nice of you to help
