I just purchased a PVR 150. It seems to capture video fine (sound and white out problems as noted by others).
I've used both WinTV2000 and GBPVR to capture video from old VHS tapes. I am then using InterVideo's DVD Creator to edit the capture and burn DVDs. The DVDs look good for the first 30 minutes to an hour of playback. Eventually though, blocks of pixels begin to drop out. If I fast forward to the same section of the DVD without playing into it, the sections play fine. Is this a problem with the settings used when capturing the video?
I have been capturing and burning home movies with the Intervideo Software for over a year using the same stack of Maxell 8x DVD-R media with no problems. Since I am using the same authoring/burn operation, I assume the problem is on capture. Can this only be a media/burn problem?
Could be media. Is that RITEKG05 or MXLRG03 media?
Wanted to say that after many hours of work trying to determine the problem, it was the labels. Peel them off, DVDs play fine.
capture VHS with Hauppauge PVR 150?
By shun in forum Capturing and VCRReplies: 13Last Post: 24th Jul 2010, 18:11 -
converting old VHS tapes to DVD
By ggg913 in forum Authoring (DVD)Replies: 3Last Post: 11th Sep 2009, 14:02 -
Converting VHS tapes to DVD
By mnewxcv in forum Capturing and VCRReplies: 42Last Post: 10th Dec 2008, 17:44 -
Converting VHS tapes for the ignoramus
By Fogg in forum Newbie / General discussionsReplies: 16Last Post: 27th Oct 2008, 19:01 -
Converting VHS Tapes To DVD
By dbuser2 in forum Video ConversionReplies: 68Last Post: 23rd Jul 2008, 02:31
