Hi guys,
i would like to make the subtitle to be permanent with the AVI movie.
is there any tool to combine subtitle into AVI file? DO i have to re-encode it again??
Thanks you guys
To perminatly encode subs, yes you have to re-encode. From your other post it looks like you really want an mpg. I would not suggest re-encoding to an avi, just to then re-encode that. Waste of time and it will result in lower quality unless you use a lossless codec.
how to add permanent subtitle to avi video?
By Sh@DY in forum SubtitleReplies: 4Last Post: 4th Oct 2011, 12:41 -
Permanent .avi file fix?
By Smack2k in forum Video ConversionReplies: 2Last Post: 18th May 2011, 02:44 -
How would I combine 2 avi files into one?
By Variable in forum Newbie / General discussionsReplies: 7Last Post: 27th Sep 2010, 16:50 -
Permanent subtitles with avi+srt to flv
By nunrg in forum SubtitleReplies: 3Last Post: 20th Mar 2008, 08:40 -
Add permanent subtitles to an AVI file using a MAC?
By blueblitz in forum MacReplies: 1Last Post: 15th Oct 2007, 05:10
