I'm using TMPGENC (the latest version) and I wanted to encode a quicktime file (.mov) to a VCD NTSC encoded mpg file. TMPGENC says the format is unsupported and won't encode when it says it does encode .mov files. I went to see if I needed some plug-in through the guides on this site but I ran into a broken link under quictime plug-ins for problems in conversion to VCD using TMPGENC guide. Is there something I can change so I can encode this file or is all hope lost?
Results 1 to 11 of 11
You'll find the plug-in over at http://www.doom9.net/
Click on "downloads" then click on "main software page" at the top. The plug-in is listed under the 'encoders' section
later
baz
Thanks but how do i get tmpgenc to recognize the newly downloaded plug-in...because its not an exectuable file
put the file in the same dir as TMPGenc and then open tmpgenc and go to the settings and put a check by the mov plugin... should then work
Is it just me, or when you try to convert mov to avi, it says ILLEGAL FLOATATION... or some shit like that?
Is there a certain title I should look for to check off? Because I don't see any obvious quicktime plug-in check box. Or maybe I'm looking under the wrong tab in settings.
and I'm also getting that illegal decimal calculation as well. I went to apple.com and made an account and didn't really know what name the file went as in the download list. Is it in the archive?
.......does anyone know how to check off the quicktime option in tmpgenc?? Because the qt plug-in that i have, that i got from that doom site posted earlier, is not the newest because i'm getting an illegal floating decimal.
I believe the TMPGenc plug-in only works for QT4 and under. If the QT mov you're using was made with QT5, it won't work right. Other times, the audio track of the QT movie is protected, and needs to be recorded seperately with a program like TotalRecorder (excellent program). Try RadTools to convert the video to AVI, and merge with TMPGenc for a nice, mangaeable mpg.
mijman,
I followed the tutorials under How To> Convert for .mov to VCD. However, when I used Rad Tools, the resulting video had no audio. So I downloaded Total Recorder (as you and the tutorial said), but whenever I attempt to record the audio from the Quicktime video, the audio plays very choppy and won't play correctly. I then exit Total Recorder and then the audio plays fine again. Do you know something that I can do?
Problem with audio when converting AVI to MOV
By emmajane in forum Video ConversionReplies: 5Last Post: 6th May 2011, 11:23 -
Problem Converting AVI (DV) to MOV (DV)
By Casho in forum Video ConversionReplies: 3Last Post: 15th Feb 2011, 06:27 -
mencoder wont convert the complete file, mov to avi|mov
By bjornieB in forum Video ConversionReplies: 2Last Post: 19th Nov 2009, 08:42 -
.mov to .avi problem - no audio
By nagel in forum ffmpegX general discussionReplies: 2Last Post: 11th Oct 2008, 10:14 -
ffmpegx problem: no audio from QT mov to avi
By mekon in forum ffmpegX general discussionReplies: 5Last Post: 1st Feb 2008, 17:14
