And save the audio file to fix and rejoin with the video? I keep having sync issues with Ulead VS and I just need a program that will do this one simple task.
Results 1 to 10 of 10
You can demux audio using virtualdubmod or pvastrumento. Both are freeware.
You can remux using ImagoMPEG Muxer or virtualdubmodbits -
Thank you, I'll give them a try. I downloaded a trial version of Pinnacle, but couldn't figure out how to split the audio. I've also tried to use Adobe premiere in the past, but it never wanted to open any of my Mpeg2 files.
New question. Ok, I've created my audio file using VD. Now, when I try to open my video file with the Imago program, it doesn't list my video as an option. I'm guessing I need just an Mpeg video file. How do I strip the audio and leave only the video? Also, how would I go about joining the audio and video back together using VD? I didn't see a guide, and it's simpler for me to ask rather than waste a buttload of time trying to figure it out.
To create an mpv (video only) file and the corresponding mp2 (audio only) file I suggest using PVAStrumento (freeware)
- Open PVAS and load in your mpg2 file (video and audio)
- Choose 'demux'
- Where is says 'Basename' browse to the folder where you want the mpv and mp2 files (you should setup this folder before hand)
- Make sure the file extension in MPEG Video is mpv
- Make sure the file extension in MPEG Audio is mp2
- Select start
- Check the folder to be sure there are two files
To verify that everything went right open Imago and choose the mpv file you just created. You should see that it also chose the audio file that was in the same folder with the same name as the video file.
Tell it to multiplex and if it does and the video plays with audio then everything is as it should be.bits
Best program to split .ts audio from video?
By R55B in forum EditingReplies: 1Last Post: 30th Oct 2010, 08:09 -
What's the quickest/easiest way to cut something from DVD and DivX
By dsajkw in forum EditingReplies: 2Last Post: 2nd Sep 2010, 11:50 -
easiest way to split audio and video
By ir0n_ma1den in forum Newbie / General discussionsReplies: 1Last Post: 1st Jun 2009, 20:21 -
What is the easiest program to convert MKV to AVI (without audio)
By Mylo in forum Video ConversionReplies: 2Last Post: 22nd May 2009, 16:52 -
What Is The Quickest/Easiest Way To Shrink MKV File
By Teac23 in forum Video ConversionReplies: 2Last Post: 19th Feb 2009, 03:56
