In general what is the best cd or cd brand for burning data, not nessacerialy just vcd's. Thanks.
They all record the same, but for durability, stay away from anything that is silver on top can scratch easy down to the data. I think HP has the best media.
I read somewhere that Verbatim were good - no coasters. My experience is that with the right software, Verbatim did indeed work well.
Dale -
From personal use I found that Sony makes the best media. I use an iMac with built in CD-RW drive and for some reason it would reject most Memorex and some Verbatim discs. I know that most NON iMac burners work fine with everything, but if my burner was having problems with CD-R's that work fine that must tell you something. The only drawback is that you have to pay between 25-30 dollars per 50 pack. Also, stay away from black bottomed CD-R's, they won't play in some audio systems that can normally accept CD-R's.
-bonks
Is VUESCAPE an ok brand?
By yoda313 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 10th May 2009, 20:13 -
Best brand for dvd-r
By jyeh74 in forum Newbie / General discussionsReplies: 4Last Post: 18th Mar 2008, 00:49 -
Brand new member
By DavidCWM in forum Off topicReplies: 13Last Post: 9th Feb 2008, 02:02 -
Best brand of laptop?
By Tbag in forum ComputerReplies: 16Last Post: 7th Feb 2008, 23:59 -
What brand DVD-R is best for the G5?
By Rich W in forum MacReplies: 5Last Post: 23rd May 2007, 20:08
![Computer details: Macintosh OS X.2.2
500 MHz PBG4 [1st Gen]
20 int / 120 ext
512 MB
Firewire
Sony DVP-NS715p
None
Internal
Pioneer DVR-104
Pioneer DVR-104
G4
Comp](/images/buttons/computer.gif)
