the only program that can capture video from my cam (jvc) is imagemixer (i have 1.7 ver), but the video resolution after capturing is very low 320x240. how can i capture with better res.?
thanks
So the JVC cam is DV?
Your Windows machine should work fine and capture at full resolution.
Try some of the capture tools available from this site.
WinDV should capture at full resolution.
Scenalyzer Live should work also. -
I'm assuming it's a digital8 or mini DV cam and your using the USB cable? The USB cable is for web quality video only on nearly every cam.
Get a firewire (AKA 1394 or I-link) cable, you can capture at the fullest resolution using nearly any capture program. It's not actually a capture but a transfer, simialr to copying a file from the cam to computer.
Edit: BTW if it's a digital still camera with video capability you need to increse the resolution in the menu on the camera. Most don't go above 640x480. -
Also, if it is a DV cam and you are playing back with Windows Media PLayer, make sure the performance settings are set to high for Digital Video, or it will look like 320x240 on playback, even if it is full D1 res.
Read my blog here.
Low res in Text presentation
By jairovital in forum EditingReplies: 5Last Post: 4th Aug 2010, 18:31 -
Looking For High Res Animation Advice
By David Bethel in forum Newbie / General discussionsReplies: 119Last Post: 8th Mar 2010, 12:09 -
320x240 res video onto dvd
By scarypoultry in forum Authoring (DVD)Replies: 3Last Post: 12th Aug 2007, 17:30 -
HELP WITH RECIEVING CLEAR 1080i RES
By sicl6lsic in forum DVB / IPTVReplies: 7Last Post: 11th Jul 2007, 09:24 -
Advice on High Res Video Capture Hardware
By Gregus in forum Capturing and VCRReplies: 3Last Post: 15th Jun 2007, 15:54
