In advance an apologie for such a dumb, silly and stupid question...but here it goes:
I hadnīt used a bit rate calculator before since I usually make DVDs from videos shorter than one hour. But now I have to fit a two hour AVI video in a 4.7 DVD and would like to use VBR to achieve better results(less quality loss I hope) since compression will be higher than my other projects.
Like I said, I hadnīt tried it before but went to: https://www.videohelp.com/calc#calc
and typed the lenght of the video(in this case 2 Hrs, 13 mins, 5 secs), with an audio bitrate of 320 (audio is important)...the result is:
Calculated Bitrate= 4255 and DVD Max Bitrate= 9472
Now for the actual question....Does this apply only for Constant bit rate?, If I select Variable should I keep 4255 kbits/sec as the AVERAGE bitrate?Then, wht should I put as: MAXIMUM? In that same example; what values would be optimal for Average, Max and Min so the video fits the DVD and I retain most of the quality?
Sorry again and Thanks in advance...
Yep, spot on. 4255 is for CBR or the Average if using VBR. I generally use about 50-100 less than what the calc tells me to allow for a basic menu as well. I'd use 1000 and 9000 as your min and max.
http://members.dodo.net.au/~jimmalenko/calc.htm is another bitrate calculator and it gives you recommendations for max and min, as well as GOP structure.If in doubt, Google it.
What is the best Bitrate Calculator ?
By Simmons in forum Video ConversionReplies: 6Last Post: 15th Jan 2011, 08:08 -
bitrate calculator for multiple audio?
By ecc in forum Video ConversionReplies: 4Last Post: 4th Sep 2008, 20:25 -
bitrate calculator
By pcb in forum Newbie / General discussionsReplies: 9Last Post: 1st May 2008, 11:34 -
videohelp bitrate calculator question
By mrgain in forum EditingReplies: 5Last Post: 24th Oct 2007, 15:56 -
Real media Bitrate calculator?
By ViB in forum Newbie / General discussionsReplies: 1Last Post: 1st Jun 2007, 13:34
