Hi im using a program called X Video Converter to convert a dvd .vob file to mpeg-1 and the program gives you a choice of different codecs to use with the new file. I was wondering what one is is a popular one and that will work with my dvd player because i used the default one which was a divx codec and i could only see black when it finished converting.
I also want to know if there is someone where i can go to find out exaclty what codecs I have on my PC.
IIWY, I wouldn't use that app. Also, you shouldn't use any codec besides the target (MPEG1).
Go with DVD2AVI (or whatever it's successor is) and then frameserve Virtualdub to TMPGEnc, for a high quality downconversion.
Or for more All-in-one approach, use DVD2SVCD.
Scott -
Tmpgenc can probably load the VOB files directly and then encode to mpeg1. If not, you could load into virtualdub-mpeg and frameserve to Tmpgenc. The mpeg1 encoding in Tmpgenc is freeware.
Melde Melda Vessė
Eruanna ar Eruntano Melda Eruntanohini
"May your days be bright and contact with stupid people limited." -
my problem acually turned out to be when i splitted the .vobs files using DVD decrypter. now when i try to view the .vob its black with no audio. how can i split the .vob without changing it?
Since you apparently want to end up with a VCD you can play on a settop player, you might look at this guide: https://www.videohelp.com/sefy/?id=ClassicalGuide.html
It uses VCDEasy and the freeware version of TMPGEnc encoder. -
Go back to DVD Decrypter and re-rip, this time setting the VOB files to not split at all. Then continue with your processing/converting.
Cannot display or convert video that uses AVC1 codec?
By peggypwr1 in forum Newbie / General discussionsReplies: 12Last Post: 4th May 2011, 04:19 -
convert video with Photo JPEG codec and MS IMA APMCD audio codec
By devil_doll in forum Video ConversionReplies: 3Last Post: 21st Jan 2011, 14:10 -
convert flv to mp3-error: unsupported video codec (7)-any remedy?
By lilly333 in forum Video ConversionReplies: 4Last Post: 21st Nov 2009, 14:28 -
failure to convert flv to Avi file because of unsupported video codec
By 2thvideo in forum ffmpegX general discussionReplies: 10Last Post: 30th Jan 2009, 12:54 -
Can't convert screen capture video (MSU SCLS codec)
By nonsey in forum Video ConversionReplies: 13Last Post: 27th Apr 2008, 04:20
