Looking for opinions on the best methods to cut out a 20 sec clip from an Xvid file, then convert to MOV/WMV. I have 180 clips so I'm looking for the most effecient methods.
I was cutting with mpeg cutter from Boilsoft then
Converting with Video Cleaner (riverpast) Xvid > Mov/WMV
I realized cutting an Xvid caused problems because of the compression (I think) Getting Bframe Lag Errors when I convert to WMV/MOV. I'm also getting inaccurate cuts because of the I/Bframes (or something?).
Needless to say, can anyone give me some advice. Should I convert the Xvids to something else, then cut and convert again or ..?
thanks for the suggestions.
Video Noob
you can cut with fairusewizard when you convert to xvid. change set the start and end.
FAST RENDERING of Final Cut Studio Pro and After Effects files.
By Kevin Whelan in forum MacReplies: 3Last Post: 24th Aug 2011, 11:40 -
Fast Foward / Rewind xvid or mpg?
By fredfillis in forum Newbie / General discussionsReplies: 3Last Post: 8th Nov 2009, 04:06 -
FAST convert to Divx or Xvid
By nerys in forum DVD RippingReplies: 23Last Post: 2nd Oct 2008, 00:30 -
Fast DVD -> MPEG4 (DivX/XviD)
By zmaki in forum DVD RippingReplies: 2Last Post: 28th Feb 2008, 14:50 -
Fast simple way to resize Xvid
By Maxwellbest in forum Video ConversionReplies: 8Last Post: 2nd Feb 2008, 17:32
