earlier in this forum I tried to determine the manufacturer of a Compusa brand generic DVD +/-RW writer. After some research I find out it's an AOpen DVD writer made expressly for Compusa without a corresponding AOpen model number with the same specs. (a made-in-China special!) I have also determined there is no firmware update/upgrade for this (and may never be).
I have no real problems with the compusa AOpen DVD writer other than some "burning" issues (media and software I think) and it was purchased cheap.
I may never need a firmware update but thought I would mention buying a name manufacturer's model you do get a little more support with "firmware" updates.
Results 1 to 1 of 1
(HCenc) WARNING, small source mismatch found in pass 2, ...
By KKPHM in forum Authoring (DVD)Replies: 13Last Post: 19th Dec 2015, 09:37 -
How to Record using 3 External Burners plus 2 Internal Burners with Speed
By mn072065 in forum DVD & Blu-ray WritersReplies: 2Last Post: 11th May 2011, 19:27 -
XP does not recognize my DVD writers as DVD writers thinks they're CD write
By steve1040 in forum DVD & Blu-ray WritersReplies: 5Last Post: 25th Jul 2008, 02:52 -
Better DVD Writers
By gameroftheuk in forum DVD & Blu-ray WritersReplies: 2Last Post: 30th Sep 2007, 14:51 -
lower cost HD DVD-ROM @ compusa
By Heywould3 in forum ComputerReplies: 4Last Post: 16th Jul 2007, 16:28
