What I mean is that I have rotated a video clip but now my subject looks squashed. Is there any way to rotate the screen too? The screen is rotated in vdub but is playing back squashed. I'm running it through TMPGENC and that is where it's getting squashed. I need to run it through 240 by 320 instead of 320 by 240 but that option is grayed out.
Results 1 to 10 of 10
I tried rotating a clip in Virtual Dub with it's filter and the aspect ratio of the display was wrong as you indicate. When I rotated it with Avisynth and opened the script in Virtual Dub the display was correct.
I don't have TMPGENC installed on this machine so I can't check further until this evening. -
Yes, Baldrick. In TMPGENC 3.0 that option is greyed out. Here's a link to the file in question after being run through RAD to convert from .mov to avi, then vdub to rotate, TMPGENC 3.0 to convert to wmv then WMM to shrink further.
http://myfavoritevideoclips.com/therob.wmv -
okey, tmpgenc xpress...never used it...can't you load some unlock template? or doesn't the help mention how to unlock settings?
and you can use avisynth to rotate, make a video.avs with notepad that just contains:
TurnRight(DirectShowSource("c:\video.avi" ))
and open it in tmpgenc xpress. -
When I opened it in Windows Media Player 9 the first quarter played rotated and then it rotated the screen 90 degrees. I'm assuming you did not change the orientation during encoding. In other words you ran your rotate filter in Virtual Dub for the whole length of the clip?
Right. I'm doing this for a chick who shot this at a concert. All I kept thinking to myself was, 'you were doing just fine, why the hell did you flip the camera?' She said some dudes head was in the way. I'm pretty much lost at this point. I just sent her this link with a flipped player - haha!
http://myfavoritevideoclips.com/therob.html
Best program to rotate videos?
By Amuse in forum EditingReplies: 10Last Post: 19th Feb 2014, 11:29 -
Rotate image
By liamdale in forum Newbie / General discussionsReplies: 2Last Post: 18th Apr 2010, 12:07 -
Rotate .MOV file
By Leo48 in forum Newbie / General discussionsReplies: 6Last Post: 22nd Apr 2008, 00:34 -
How to rotate video playback screen?
By manoa in forum Newbie / General discussionsReplies: 5Last Post: 5th Jun 2007, 14:09
