hey guys,
does any1 know how to convert .nsv vide files (Nullsoft Video Format) to avi or mpg files??
Results 1 to 9 of 9
Old and Bored
Yet Self assured
Oh I know a dirty little word -->Encryption -
goooooooooooooooooooooooooogle!
http://66.102.9.104/search?q=cache:ql4HuwpRmJgJ:www.hollmen.dk/articles/nsvtoavi.htm+%...o+avi%22&hl=sv -
.nsv are Nullsoft video files. There is an encoder called nsvtools.exe at www.nullsoft.com/nsv/ but not sure if its backward compatible as its mainly aimed at encoding TO .nsv format. Worth a look anyway. Also suggest you start with Winamp as these files are associated with them.
Check out
http://forums.winamp.com/showthread.php?postid=1040011#nsvenc
for starters.
May also try a VP3 enoding search as the video tends to be VP3 and audio Mp3-possible demuxer could be coolbeans.exe. This is as much as i know-apologies could not help further.
Baldrick and Guns1inger know much more than me so give them time to count all those 'o's and i'm sure they'll post back with a more definitive answer. -
I've tried only on NSV files which contained VP62 video and AAC audio, and successfully converted them to XviD/MP3. I first demuxed the NSV file using NSV Demuxer (NSVD.exe must be used within a dos prompt window) and ended up with one video file and one audio file. I then used SUPER, which uses mencoder internally, to convert the video into XviD and I think I actually used GraphEdit to convert the AAC file to wave and then BeSweet to convert the wave to MP3. Lastly I muxed the video and audio back together using VirtualDubMod. While searching for a way to do this I did read somewhere that if the VP video contains any errors NSVD.exe will not demux properly and I couldn't find any way to fix it. Hope this helps. 8)
need streaming nsv (nullsoft video) with widescreen help
By br33zi in forum Video Streaming DownloadingReplies: 1Last Post: 12th Feb 2012, 15:43 -
Dazzle dvc100 w studio 12 does it capture AVI 1 or AVI 2 or DV-AVI
By st711 in forum Capturing and VCRReplies: 1Last Post: 10th Dec 2009, 17:30 -
ffmpeg choppy audio from large avi but not small avi source file
By cybertheque in forum Capturing and VCRReplies: 9Last Post: 13th Oct 2008, 15:38 -
ffmegX v0.09w and converting avi videos into avi.ff.avi videos
By paddymick in forum ffmpegX general discussionReplies: 2Last Post: 2nd Nov 2007, 23:10 -
How To Split Single DV AVI file into Multiple DV AVI files using Time Stamp
By insysnet in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 23rd Aug 2007, 12:49
