    Dec 2002
    Hi, I got a video which was encoded using X264 723k + AC3 192k, I have installed the x264 Video Codec rev. 341, but it doesn't play as codec was not recognised? Could some1 pls advise if another codec is required pls, thanks.
    video player - viplay
    OS - xp pro
    Apr 2004
    Miskatonic U
    Try VideoLan, which has it's own codecs and seems to play pretty much anything
    Read my blog here.
    or ffdshow and enable h264/x264 under video deocoder options->codecs.
    Dec 2004
    Australia
    x264 is either a commandline app or VfW and it doesn't include a decoder. Also with AC3 audio I am guessing that it is in an mkv container? If so then you also need an mkv splitter.
    As said ffdshow is the way to go for dshow playback. VLC tends to be out of date. Nightly builds should be ok, although I am not sure if libavcodec gets updated nightly as well.
