Under hacks - there was one post under the Sharp DV HR350 that indicated I should email if I wanted the Hack. But how do I email? Are email address listed somewhere?
the comment is below:
Region code hack posted by Daz, June 18 2005:
Region hack requires to play one cd then another in the player. Please email and
I can send you the files in a zip file and you burn 2 CDs from them and follow
instructions. File is around 2.5 Mb in size.
Click their profile button, it will be listed there providing they have allowed it to be viewable.
Thanks coalman,
but the under the DVD Hacks section when a user posts a Hack tip, it is not possible to click user profile. It only lists the posters name.
Is there a way to search the member lists for that member and then check the profile.
When I try the search option, it seems to search forums but not by member. -
If you look at the top of this thread, it has the "Advanced Search" where you can search by "Author"Originally Posted by razdoctor
Which will bring you to this page...
https://www.videohelp.com/forum/search.php#search
And if you do a search... you will see his latest post... then you can click his name and see, this person only made 1 post... over 3 years ago
https://www.videohelp.com/forum/profile.php?mode=viewprofile&u=25638
And has no contact info at all.... except a PM through here... but after 3 years with 1 post.... i would not hope for much
Contact of Gmail
By Jomapil in forum ComputerReplies: 4Last Post: 11th Aug 2011, 11:47 -
UN selecting Ambassador for Alien Contact
By deadrats in forum Off topicReplies: 2Last Post: 28th Sep 2010, 11:48 -
XviD4PSP contact
By leghorn in forum Video ConversionReplies: 7Last Post: 31st Dec 2009, 10:19 -
Anyone have contact info for tmpgenc.net?
By TheEvilHammer in forum Newbie / General discussionsReplies: 1Last Post: 19th Oct 2007, 02:45 -
MyFilms - A Software I Wrote
By qknet in forum SubtitleReplies: 0Last Post: 28th Sep 2007, 03:47
