I've noticed in both commerical vcd's (mpeg 1 ) and my own encoded DivX videos and elsewhere that often Strong red colours/scenes in videos often seem to be pixelated or show lots of jagged edges.
Is there any reason for this? I have not noticed this phenomena with any other colour
I have noted this too. Its a very good question, and I would like to figure it out too.
I think it has something to do with MPEG-1 and MPEG-2 compression (I know that doesn't answer your question, nor mine)...
Should be noted that if you view these "pixelated" red areas on an analog TV, they merely look "sharp", at least that's my experience. Only on a computer monitor does it look strange. -
Anyone else have any ideas?
Is this question better suited to a diff section? I don't wana repost for no reason -
yes, it happens with red. And only red. This happens only when i playback VCD's on my monitor, on my TV the jagged edges are smoothened like all other colours. Now to why it happens.
The reason that red appears jagged is because the colour space equation used. YUV 4:2:0 means that you will lose resolution on colours, moreso red. Since VCD cannot be made in 4:2:2, or 4:4:4, there is no solution to this problem.
4:2:0 means that the colour components are divided by four, 4:2:2 means the colour components are halved, 4:4:4 means there is no loss in colour components. -
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
Yep. -
This phenomena is still very noticeable in Divx captured in YUY2 YUV 4:2:2 interleaved (acording to vdub anyhow)
Is this for the same reason?
Correcting colours in CS4
By sterankin in forum EditingReplies: 2Last Post: 6th Sep 2011, 06:24 -
I need a genuis!!! Heavily red tinted or red hue.
By mikekrauser in forum Authoring (DVD)Replies: 4Last Post: 16th Aug 2009, 20:51 -
Camcorder changes original colours
By marklewis in forum Capturing and VCRReplies: 2Last Post: 31st Mar 2009, 13:40 -
colours are weird?
By bennyboyt in forum Newbie / General discussionsReplies: 5Last Post: 23rd Dec 2007, 20:47 -
funny colours in quicktime
By Shaorin in forum Newbie / General discussionsReplies: 3Last Post: 30th May 2007, 19:17
