Ok, where to begin. I was following Galactica's guide for converting SVCD to DVD (ffmpeg, sizzle and toast) and my first problem came up when i was trying to add the converted-to-48khz .mp2 files to Sizzle. It kept saying that they werent .mp2. I got around this by using Sizzle 0.5b1 (not b2).
Next. I author the dvd, burn it, stick it in my player and i scan forward to make sure everything looks right. It cuts to the ToC menu at the end of what would be the first SVCD file. I havent found a way around this besides the following:
Third: To get around this, I re-muxed the three files and used MPEG2 Works (demo) to join the files together. I check the integrity of the movie, its fine. I demux this new 2gb-ish file and proceed to go about as normal in Sizzle. Everything is accepted, but the resulting .dmg file is only covers a third of the movie. This boggles my mind to no end. I tried it in both 0.1 and 0.5b1 and the same result.
Any help at all would be appreciated, even if it shows how much of a newbie I truly am.
<edited for correct app name>
Problems with chapters in DVD authoring/audio temporarily off-sync
By nocomments87 in forum Authoring (DVD)Replies: 7Last Post: 9th Nov 2011, 08:44 -
Audio problems with authoring
By moes in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2009, 15:27 -
Authoring Problems
By DJvoo in forum Newbie / General discussionsReplies: 2Last Post: 10th Apr 2009, 06:58 -
How do I do this with Sizzle (dvd authoring tool)?
By master_debator in forum MacReplies: 0Last Post: 27th Aug 2007, 13:45 -
Follow up : audio problems with VCD authoring
By thelotusman in forum Authoring (VCD/SVCD)Replies: 5Last Post: 9th Jun 2007, 18:34
