how do i extract audio from an avi file?
all i want is the audio and i would like to save it as .wav??????
http://members.dodo.net.au/~jimmalenko/ExtractAudio.htm
https://www.videohelp.com/guides.php?guideid=837#837
One uses virtualdub, the other uses virtualdubmod.
You should also be able to do this using Goldwave.If in doubt, Google it. -
Yes, easiest way is to just load the AVI in Goldwave, then Save. Done.
/Mats
How to make audio / video business card and website audio/videos clips
By tmh in forum Newbie / General discussionsReplies: 6Last Post: 4th May 2011, 12:25 -
Will Sony Vegas work with a high end audio interface used for digital audio
By fuzzblaster in forum AudioReplies: 3Last Post: 1st Sep 2010, 18:24 -
removing the commentary audio track from an AVI file with mpeg layer3 audio
By wildrthanevr in forum AudioReplies: 1Last Post: 10th Mar 2009, 02:29 -
Easy DVD to MP4/MKV with Dual Audio, 'soft' Subtitles, and 5.1 Audio?
By Grovest in forum DVD RippingReplies: 4Last Post: 3rd Nov 2008, 05:12 -
demux audio from avi then two audio sources(aac 2ch + ac3 6ch)
By fatcat23 in forum ffmpegX general discussionReplies: 4Last Post: 21st Sep 2008, 02:19
