Hey everyone. I was wondering if it was possible to extract just a menu from a DVD so I can use it for another DVD I'm burning. I need to be able to use the background video, audio, fonts, etc., but I need to move it to a different DVD, change the text to different names, and then link the text to the movies in my DVD. Is this even possible? I've looked on the boards and guides and I can't find anything like this.
MenuEdit can edit existing menus, and I'm pretty sure tools like DVD-lab Pro and/or DVDRemake can probably import already-made menus in - you just need to redo all the links then.
If in doubt, Google it. -
Cool... Now how would I extract just the menu from the other DVD... or should I post that in the Ripping forum?
demux the menu with vobedit, https://www.videohelp.com/forum/viewtopic.php?t=280500&highlight=extract+menu+dvd
Extracting menu buttons
By headless chicken in forum MacReplies: 0Last Post: 3rd Apr 2012, 00:54 -
Panasonic DMR-EZ48VK How do I get into its hidden setup menu (Service Menu)
By RS456 in forum DVD & Blu-ray RecordersReplies: 20Last Post: 14th Nov 2011, 02:50 -
Extracting and editing an existing DVD menu
By sambat in forum Authoring (DVD)Replies: 18Last Post: 21st Mar 2010, 18:23 -
Extracting DVD menu and re-using them?
By zhiwei1710 in forum Authoring (DVD)Replies: 2Last Post: 17th Feb 2008, 07:52 -
How to create IFO &BUP file for DVD menu[have menu vob]
By Aliyans in forum Authoring (DVD)Replies: 3Last Post: 28th Dec 2007, 12:36
