i recently taped a concert at a festival and made the mix of it in 5.1 surround using sonic foundry Acid 4.0.
now i am having trouble getting this to dvd.the project has saved the left,right,centre and both rear outputs as seperate .wav files.how do i get these all to play as one 5.1 surround mix also making an animated background out of the photos from the festival itself.
thanks
If you have Vegas, just load them into Vegas as seperate tracks, check the positions and create an AC3 file. If you need a free solution, ffmpeggui or besweet can create a 5.1 ac3 file.
The photos can be mixed using either something like memories on TV or similar, or a video editor with motion capabilities (Premiere, Vegas etc)
What authoring software do you have ?Read my blog here.
the only software i have is the tempegenc dvd creator,have`nt used it for ages.i also have pinnacle studio 9.3+.
what i`m looking for is the dvd to play the 5.1 mix with edited photos possably animated or with effects on the screen while the dvd plays.
thank you -
As it's been suggested you can use Vegas to make your video compositing and also to encode your audio files to 5.1. As far as I know you can also use Premiere to join all these audio files to get a final 5.1. DVDA is another option: as fas as you have your final 5.1 file, you can use DVDA to create a simple slideshow. Please note that all of them are not freeware. Anyway, I guess you can use you software - pinnacle - to composite your video too.
I don't know about other software but I'm pretty sure most of the lower end software will reencode the 5.1 track as being "non-compliant".
DVDWS is one authoring program that will work with 5.1 audio files providing you already have a compliant 5.1 AC3 audio track. It's as simple as directing it to not reencode compliant tracks. It won't create a 5.1 track though. -
-this is absolutely true.I don't know about other software but I'm pretty sure most of the lower end software will reencode the 5.1 track as being "non-compliant".
How to convert DVD project to Blu-Ray project??
By zentsang in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Jul 2010, 18:08 -
Help Neeeded For DVD Project. Extract DVD Menu For Use In Personal Project
By sephiros in forum Authoring (DVD)Replies: 2Last Post: 5th Nov 2008, 13:49 -
Garbled Audio in Nero Dvd project - Video is fine - need assistance please
By RossChurchill in forum Newbie / General discussionsReplies: 2Last Post: 17th Jan 2008, 16:44 -
No audio after converting project to AVI
By gwlnl in forum AudioReplies: 3Last Post: 23rd Nov 2007, 15:55 -
Burning multiple copies of a project using Audio DVD Creator
By scratcher in forum AudioReplies: 2Last Post: 28th Sep 2007, 17:28
