  1. ive been looking at some guides here, but .. is there an easy way, fast, without having to use so many tools, for audio, and all of that stuff..i have a few movies in SVCD format, which each CD is a CUE/BIN file..im tired of burning two discs to watch the movies, now i got a dvd burner and i want to be able to put those files into 1 DVD-R/DVD+R, but i know i have to convert them first, i have a few tools, *TMPGENC* i will not use, it gets to complicated, i also have NERO, DVDdecrypter, ISOBUSTER, what can i do?
    PLZ help!
    Thanks in Advance
  2. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    SVCD2DVDMPG should be able to do this relatively simply. It can create your MPEG file(s) ready to author. You'd join two or more parts in the authoring process.
    If in doubt, Google it.
    Apr 2005
    Michigan, USA
    I'm with jimmalenko ... I think that SVCD2DVD would also do the trick for you.
    SVCD2DVDMPG is freeware; a demo version of SVCD2DVD is available.
