Page 2 of 2
FirstFirst 1 2
Results 31 to 36 of 36
  1. Make them B&W with an ALFA.
  2. I find the best looking Overlays are just Out lines of the Button you are using Or somekind of Object.,Dont mix these with Highlighted Images.
    Jan 2004
    Canadateck, have you used this DVD Menu Studio?
    I got it because it seems perfect for what I want (be able to create layered menus without dealing with photoshop) It's great because it's all geared toward creating DVD menus.
    So I created my menu, there's two layers, one with the background, the other with the subpictures. I exported it to PSD , opened it in Ulead, but in the 5 "options" i created in the menu, well it basically made them all as one object, not 5 separate ones....
    any ideas why?
    It's a single object, but the "layers" can be used separate from one another.
    Jan 2004
    how does one go about that?
    When I import the PSD under the "object general" library, it opens it fine, and then i discover there are two objects, the background, and then the subpicture, but the bounding box is around the entire list of selections, so it's one object, and not five like I needed...Perhaps I should post a screen shot of what i'm talking about..
    Mar 2005
    Australia
    DVDWS2 is SO simple to use even an ape could be trained to create a great menu in 20 mins.
    found a basic menu creating guide @
    http://www.network54.com/Forum/336827/thread/1126864005/last-1127381712/Making+DVD+men...DVD+Workshop+2
    Tam
