Hi, I have been converting some vob files to 3gp using free software called SUPER off a link on this site , in order to watch the video on my mobile phone.
The video is great but the audio is far too low, I have tried increasing the audio bitrate on the software but it makes no difference.
Does anyone know of any other free software for converting vob to 3gp or any other way that I could improve the audio ?
The volume on the phone is at maximum level.
Darren![]()
It depends on the bitrate used in the dvd audio .
Normally I'd rip the dvd first
Then use ifoedit to strip video stream
Then strip the audio stream
Use besweet to convert and increase the bitrate of audio .
Use ifoedit to reauthor both video and new audio to new dvd folder .
Now use super to convert it and see how it gose .
If that dosent work , its your phone problem . -
Hi, thanks for your reply,
I have solved the problem.
I have sent back the LG U8360 phone and now have a Nokia 6630.
When I now play the same video, I have to turn the volume DOWN because it's so loud.
The Nokia 6630 is a great phone
Thanks again
Darren
Converting 3gp file to WMV or AVI without losing clarity
By brketch in forum Newbie / General discussionsReplies: 2Last Post: 18th May 2011, 08:01 -
Converting AVI (DivX/XviD) to MP4/MOV/3GP...
By JaleAlbatros in forum Video ConversionReplies: 5Last Post: 23rd Jul 2009, 18:51 -
Converting 3gp to MPEG4 .AVI
By vworley in forum ffmpegX general discussionReplies: 9Last Post: 2nd Apr 2008, 13:48 -
Converting MPEG to 3GP --> Empty Target File?
By SnakeGirl in forum ffmpegX general discussionReplies: 6Last Post: 11th Jan 2008, 01:14 -
problems converting to 3gp
By swedishlf in forum LinuxReplies: 5Last Post: 5th Sep 2007, 04:35
