Is there a problem with using all the disk space available to make a DVD? I've been told that it can cause problems because the end of the disk is more vulnerable.
Dorian
Results 1 to 9 of 9
Depends on the media. If you use Taiyo Yuden ( real ones ) you can utilize all the space without problems. The dye actually extends well beyond the recordable region. If you use junk like CMC coded stuff, Princo and the like you may not have that luxury
No DVD can withstand the power of DVDShrink along with AnyDVD! -
Staying below 4.0 GB (out of 4.3) seems to prevent skipping for me.
I go to about 4.2Gb with DVDShrink, though I've never had any problems with 4.37Gb with my DVDs. Losing that small amount of space on the disc is worth it to avoid any possibility of problems and the additional compression needed is not likely to be noticeable.
If your media brand was unknown or questionable, or you really don't want to take chances, I would go to 4.0Gb as davideck mentioned. -
Nope - Pretty bad!I use Memorex DVD-R. It that a quality media?
TY all the wayNo DVD can withstand the power of DVDShrink along with AnyDVD! -
Memorex is a brand. They plaster it on different kinds and manufacturers discs. So one day, Memorex may be fine, the next batch bad. Only way to know, is to look at the manufacturer ID, which is hard, until you've bought it. For full info on manufacturers, take a look at www.nomorecoasters.comOriginally Posted by DorianDW
Now, as I don't want to spend too much (neither money nor time) on my media, I stick to 4.2 GB when I encode a movie. I can just grab the cheapest media I find, and haven't had any problems. YMMV. If I had run a business doing DVD for others, I might be more interested in the q of the media I choose. As it is, I'm happy as long as my DVD player accepts what I shove in it.
/Mats -
Same here. Ty's are just a waste of money IMO. I buy what's on sale and haven't had any problems. Memorex has been quite reliable for me.Originally Posted by mats.hogberg
Many of us feel (rightly so if you ask me) that the best DVD-R media is Taiyo Yuden. I never use DVD+R media but I know that Taiyo Yuden also makes DVD+R discs and they are highly regarded though I don't know if they are the "best" of the DVD+R discs. However Taiyo Yuden is very clearly one of ... if not the ... best of the DVD-R discs.
Taiyo Yuden can be bought in "bulk" from a variety of websites. The most reliable ... IMHO ... is RIMA.COM
Also, historically, retail packages of FUJI that say MADE IN JAPAN are Taiyo Yuden discs with the FUJI label. FUJI packages that say MADE IN TAIWAN are NOT Taiyo Yuden and should be avoided.
I also will buy 10 packs of Panasonic DVD-R discs from time to time at BEST BUY if I am in a pinch and need some discs. The packaging says MADE IN JAPAN and they have always been Taiyo Yuden.
It is generally more expensive to buy retail than direct from a webiste such as RIMA.COM but sometimes you can get MADE IN JAPAN packages (with the Taiyo Yuden discs) of FUJI on sale. Otherwise it is cheaper to buy on-line.
avstodvd disk space
By nhn21 in forum Authoring (DVD)Replies: 3Last Post: 6th Aug 2010, 16:16 -
not enough disk space - Adobe premier Pro 2.0
By Reggie6966 in forum Newbie / General discussionsReplies: 11Last Post: 8th Nov 2009, 04:07 -
Why am I losing so much disk space?
By Han Solo1 in forum ComputerReplies: 7Last Post: 24th Nov 2008, 21:17 -
Super eats all my disk space
By ZenSojourner in forum Video ConversionReplies: 10Last Post: 21st Oct 2007, 03:27 -
Hard Disk Space When Encoding
By Em in forum Newbie / General discussionsReplies: 8Last Post: 21st May 2007, 13:35
