  1. An unsuccessful attempt at transferring files via direct cable connection between a Win98SE desktop and WinXP laptop has resulted in the laptop being unable to access ISP's via dialup.
    AOL goes into a constant redial mode after the modems begin talking to each other.
    AT&T Worldnet gives an error code of 720, indicating the laptop and Worldnet cannot agree on a protocol setting.
    Since all diagnostics indicate the modem is functional, something I changed, deleted, or added during the cable-to-cable miscue is probably causing the problem. (And I made several I did NOT log--dumb move!)
    I have googled on this error code and found numerous fixes, but none seem to work. I've reset TCP/IP, reloaded both AOL and AT&T Dialup Manager, doublechecked every setting I can find, all to no avail. I've run virus/spyware checkers on everything.
    I've been on live chat AND telephone troubleshooting with both AOL and AT&T, but their fixes and suggestions don't work. I've sat with an IT professional who, after all his efforts were unsuccessful, suggested a reload of SP2 might solve the problem. Nope, didn't work.
    In general terms, I'm beginning to think I've overlooked a step so basic that the fixes assume NO ONE would be so dumb as to have changed/deleted it, OR, it's a VERY deep-in-Windows-XP tweak I haven't been able to find yet.
    This is my wife's laptop and she's beginning to doubt my abilities as far as computers. Since that's one of the very few positives I can offer her (my computer expertise), I'm in deep doo-doo if I don't fix this problem.
    Any ideas from anyone?
  2. Member thevoelk's Avatar
    Sep 2004
    Forest Hill, MD
    Does the connection work without the direct cable connection?
    Also, dump AOL.
  3. Originally Posted by CobraPilot
    Ask for a divorce :P
  4. Member Prot's Avatar
    Dec 2003
    Oregon
    You could try a restore point to before you attempted the file transfers. This method will retain the data files, however, but will restore the registry back to where it was before.
    Get a cheap cd burner for the desktop and transfer the files via cd.
    TANSTAAFL
