hey guys
i got a little problem with converting my mini dvd from my handycam to mpeg format.
so i finalized the dvd on my handycam. now i can play it without a problem on my dvd player with a menu and all.
but when i want to convert it to my computer with dvd decrypter there are just two complete vob files on my disc.
when i then convert it to mpeg i can't get all of the images and the sounds is horrible too.
how can i fix this
maybe it's because i finalized the disc on my handycam???
i just want to see all the scenes apart from each other on my computer
heeeeeeeeeeeelllllllp
why is my topic moved
so if someone could just tell me how to get all the different clips out of the menu that my camera created, that would be very helpfull
hopefully someone can solve my problem
i already solved a lot of my problems through this forum
you guys rock
You can use DVD Decrypter to demux the video and audio out of the vobs, which will give you two elementary streams (one audio, one video), or to give you a single VOB. Use IFO mode and select the Stream Processing tab. Tick Enable Stream Processing, then highlight the video stream and tick Demux. Do the same for the Audio Stream. You can then use ImagoMPEG-Muxer to create a single mpeg file (video and audio togther) if you need to.
Read my blog here.
Old Sony Handycam to PC
By cincy_kid in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 27th Jul 2011, 00:05 -
Want to Upgrade my Sony Handycam
By HoosierGuy in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 13Last Post: 9th Jun 2011, 11:34 -
Problem with Sony Handycam!!
By FrontierGander in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 3rd Aug 2009, 22:23 -
Using Analog Sony Handycam as a Webcam
By whataboutbob in forum Capturing and VCRReplies: 2Last Post: 28th Jan 2009, 19:18 -
Sony Handycam DVD508
By snakeplkn in forum Newbie / General discussionsReplies: 2Last Post: 20th Sep 2007, 19:20
