    May 2003
    How can you film a plasma screen TV using a DV camera and not get flicker when you play back the recording?
    I have tried to do this before, and though the video is watchable, the flicker is distracting.
    Aug 2004
    Florida
    Hello,
    My only guess would be to video tape the same program or signal, then capture and edit it..This is presuming that you cannot get to the analog output of your TV and use you DV camera as a passthru device..
    jolphil
    May 2003
    It will be at a convention, where filiming of the presentation is permitted, but you obviously arn't able to plug directly into the plasma screen (I will be in the audience).
    I think it is simply a case of the refresh rate being picked up by the camera the same as a moniter or TV. Is their a virtualdub filter to reomve that perhaps?
    Aug 2004
    Florida
    Ahhh!!
    I see now what you mean..i think you are correct about the refresh rates
    not agreeing..Dont know what you can do about that..Maybe someone else
    has a better idea..
    jolphil
    May 2003
    I have read that adjusting your cameras shutter speed to match the refresh rate of the display can stop this happening. Question is, how the heck do I do that? My camera is a Sony dcr-hc14e.
    Aug 2004
    Florida
    Hi,
    This may be far out but I see you are across the pond..Are you recording in PAL? If you could record with a borrowed NTSC camera then change it by software back to PAL..
    That would be a different frame rate and possibly not flicker..
    Just a wild thought..
    Goodluck,
    jolphil
  7. Originally Posted by cyclone5
    Read the manual? This one might be close:
    http://www.docs.sony.com/release/DCRHC1000.pdf
    Look under Recording -> Adjusting the Exposure
