  1. Version: SVCD2DVD 2.0
    Build: 2.0.2117.24512
    Type: System.NullReferenceException
    Source: Interop.CodeLock
    Message: Object reference not set to an instance of an object.
    InnerException:
    StackTrace: at CodeLock._Secure.Authenticate(String pass)
    at AxCodeLock.AxSecure.Authenticate(String pass)
    at x3284ccece41ee22b.x210ff09a2516b1a7.x41f470203acc6 a6e()
    at x3284ccece41ee22b.x210ff09a2516b1a7.x0507e45eec4e9 097(Object xe0292b9ed559da7d, EventArgs xfbf34718e704c6bc)
  2. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Did it install without Incident? Is this a fresh install or has it worked previuosly and this has only just happened?
  3. This was an 'upgrade'. It made me un-install the older build.
    This happens upon start up. But if I close it and try a few times, the programs opens without problem. However, I got that far but when I
    tried to author a DVD and convert/burn it, the same error popped up.
