forum has been searched for this - need more info,
using svcd2dvd and love it,
never had a problem................untill
file=C:\Program Files\mIRC\download\movie1.avi
Num_Frames=122998
DurationInSecs=4104
Duration=01:08:24.0
VideoCodec=mpeg4
Width=672
Height=288
Standard=NTSC
BitRate=1429
AudioStreamCount=2
Audio1SampleRate=48000
Audio1Codec=ac3
Audio1BitRate=448
Audio2SampleRate=48000
Audio2Codec=ac3
Audio2BitRate=448
=================== AV Details ===================
AVI2MPG: 3520kbs Full-D1
Looking for AVI PAR...
Leaving source audio alone.
Pass 1/1: Processing movie1.avi
17:17:19: ffmpeg version 0.4.9-pre1, build 4757, Copyright (c) 2000-2004 Fabrice Bellard
17:17:19: configuration: --enable-a52 --enable-gpl --enable-memalign-hack --enable-vhook --disable-debug
17:17:19: built on Jul 27 2005 15:48:58, gcc: 3.2.3 (mingw special 20030504-1)
17:17:19: Input #0, avi, from 'C:\Program Files\mIRC\download\movie1.avi':
17:17:19: Duration: 01:08:24.0, start: 0.000000, bitrate: 1429 kb/s
17:17:19: Stream #0.0: Video: mpeg4, yuv420p, 672x288, 29.97 fps
17:17:19: Stream #0.1: Audio: ac3, 48000 Hz, 5:1, 448 kb/s
17:17:19: Stream #0.2: Audio: ac3, 48000 Hz, 5:1, 448 kb/s
17:17:19: Output #0, dvd, to 'C:\Program Files\mIRC\download\movie1_S2D.mpg':
17:17:19: Stream #0.0: Video: mpeg2video (hq), yuv420p, 720x480, 29.97 fps, q=1-31, 3520 kb/s
17:17:19: Stream #0.2: Audio: mp2, 48000 Hz, stereo, 448 kb/s
17:17:19: Stream mapping:
17:17:19: Stream #0.0 -> #0.0
17:17:19: Stream #0.1 -> #0.1
17:17:19: Stream #0.2 -> #0.2
17:17:19: [mp2 @ 0070A780]bitrate 448 is not allowed in mp2
17:17:19: Error while opening codec for output stream #0.2 - maybe incorrect parameters such as bit_rate, rate, width or height
17:17:19: AVI2MPG: done.
Im guessing it doesnt like the bitrate !!
I thought svcd2dvd would change it for me !!
is there a program where I can run the .avi through and it will change the bitrate to an allowable one
thanks anyone
What is the SVCD2DVD build number?
here some more info
Version: SVCD2DVD 2.0
Build: 2.0.2034.36335
Type: System.NullReferenceException
Source: SVCD2DVD
Message: Object reference not set to an instance of an object.
InnerException:
StackTrace: at x3284ccece41ee22b.xd3764d4f1e921081.AuthorDVD(xc76 139390a97debb xd2637df501625a82, x81974c36d7fdf1e1 xb4ee5c1758e9e983, Int32 xdc4f66b5011a3c9d, String[] x738d70b20493db82, Boolean x6b20cb17e8070d92)
at x3284ccece41ee22b.xd3764d4f1e921081.x2e6504f39decc 498()
at x3284ccece41ee22b.xd3764d4f1e921081.xf81783e1b359f fc3()
at x3284ccece41ee22b.xd3764d4f1e921081.x12cbe7a4e46ac 9ae()
Title: 2.0
Version: 2.0.2034.36335
Executable: C:\Program Files\BadgerIT\SVCD2DVD v2\SVCD2DVD.exe
Executable size: 2.42 MB
Executable size in bytes: 2539603
Executable CreationTime: 7/27/2005 11:42:04 AM
Executable LastWriteTime: 8/7/2005 8:03:33 AM
Executable LastAccessTime: 10/25/2005 7:45:58 AM
what do you think -
Can you update to the latest build - it should be sorted.
Changing bitrate of an audio file
By prohank in forum AudioReplies: 2Last Post: 6th Mar 2011, 07:34 -
changing audio bitrate with ffmpeg
By wallywalters in forum Video ConversionReplies: 4Last Post: 11th Feb 2011, 05:45 -
Changing AVI Bitrate!
By Ace-Of-Spades in forum Newbie / General discussionsReplies: 5Last Post: 8th May 2008, 12:23 -
Changing AC-3 Bitrate
By kotton in forum AudioReplies: 5Last Post: 1st Sep 2007, 23:29 -
Resizing AVI and changing bitrate using Virtualdub and XviD
By mlwitchking in forum EditingReplies: 7Last Post: 27th May 2007, 15:45
