I'm new to this so bear with me. I've just gotten broadband and am downloading some TV shows that are in avi format. I need a media player that will play them, WMP won't and also how do I go about burning them to DVD? Do I need to convert them so they will play on my DVD player?
Any help is extremely apprecated.
Seems you were new to VCD about this time last year, hmmmmmm ?
These sections are your FRIENDS:
https://www.videohelp.com/guides
https://www.videohelp.com/tools
WMP will play them if you get the right codec(s):
https://www.videohelp.com/play#identify
If your settop player can play divx or xvid then you may be fortunate enough to not have to convert anything.
Otherwise, converting to DVD-compliant MPEG-2:
https://www.videohelp.com/dvd
http://members.dodo.net.au/~jimmalenko/AVI2DVD.htm
divxtodvd
If in doubt, Google it. -
Thanks heaps, sometimes I think I know what I am doing, but I like to check before I do anything.
How do I know which codecs I need though? there seem to be so many! -
Roughly half of all the cries for help on this forum are from folks who download TV shows in avi format and want to burn them onto DVD.
Short version: don't.
Download ffmpeg and watch your avis on your computer. Divx is incompatible in every possible way with the DVD format. Different audio sampling rate, different audio codec, different frame size, different frame rate, different everything. It takes so much time and effort to convert avis to DVD format and the results look so crappy that it's not worth it.
If you download a TV show, burn it to CD-R and watch it on your computer. Anything else is a waste of your time. -
Rubbish.Originally Posted by spectroelectro
Can be 48KHzOriginally Posted by spectroelectro
Can be AC3Originally Posted by spectroelectro
Can be 720 x 480 or 720 x 576Originally Posted by spectroelectro
Still either 23.976, 25 or 29.976 (all of which are dvd-compliant)Originally Posted by spectroelectro
There's 4 things above which can be the same. Need I go on ?Originally Posted by spectroelectro
DivxToDVD does a reputable job in a reasonably quick time. Encoders can do a typically decent job also. A lot depends on the source though.Originally Posted by spectroelectroIf in doubt, Google it.
How to convert DV avi files to DVD ready MPG files with Win7 powershell.
By findus in forum User guidesReplies: 5Last Post: 19th Dec 2011, 17:42 -
How to increase Video Sound Levels on AVI Files or wmv files
By lovebeing in forum Newbie / General discussionsReplies: 2Last Post: 28th Dec 2010, 09:25 -
How to quickly split M2TS files just like AVI Splitter works with AVI files
By hoovey1969 in forum EditingReplies: 1Last Post: 30th Nov 2009, 23:42 -
How do I put AVI files onto a DVD as AVI files?
By dgarmaise in forum Authoring (DVD)Replies: 15Last Post: 17th Mar 2008, 21:32 -
whats best to use to copy my home videos to DVD... avi files or wmv files??
By leegutcher in forum Newbie / General discussionsReplies: 5Last Post: 14th Jun 2007, 05:24
