Hi every1,
I am trying to burn a vcd of a movie file on a CD-R. But I can't burn more than one hour and nineteen minutes on the vcd. I don't think it is a problem with the size of the file because i have burned files bigger than this one but below one hour and nineteen minutes. Is there any way I can burn more than one hour and nineteen minutes. Please help me.
Thank You in advance.
80 minutes of VCD-compliant MPEG will fit on an 80 minute 700MB CD as-is.
To get more, you need to look at either overburning, 90 or 99 min CDRs, or encode as non-standard Video CD (XVCD), and lower the bitrate such that your end MPEG is roughly 800MB if using 80 min 700MB CDs.If in doubt, Google it. -
hey forget xvcd
go kvcd
with that stuff you can get more than 2 hours
foshizzle my nizzle -
Squeezing video sacrifices quality. Remember this.
Be wary of supposed superior compression schemes. They're just that ... schemes. If you want better quality, and more time, get a DVD. If a normal DVD is still not big enough, split discs or use a DL DVD.Want my help? Ask here! (not via PM!)
Burning a CD -- Minutes vs. File Size
By Opv in forum AudioReplies: 17Last Post: 5th Mar 2011, 22:55 -
One hour, 37min AVI file that I want to turn into a VCD
By penang in forum Newbie / General discussionsReplies: 23Last Post: 17th Feb 2011, 10:11 -
VCD to PSP - Audio out of sync in last five minutes
By BozQ in forum Video ConversionReplies: 6Last Post: 2nd Apr 2009, 22:43 -
Popcorn Hour
By TheRubster in forum Newbie / General discussionsReplies: 9Last Post: 13th Nov 2008, 15:10 -
burning 1 hour of raw footage onto DVD
By sfischer in forum Authoring (DVD)Replies: 2Last Post: 8th Feb 2008, 20:28
