MPEG 2 Part 2
I'm refering to ISO/IEC 13818 2:2000. Which is MPEG-2 Part 2 (Video).
It seemed edDV was trying to pin me when he was talking about codec/standard differences, so i said part 2 to make sure we're talking about compression and level/profiles here.
Ok, gotcha.post-processing
Got any links for such files? are there any standardized?standardized "Known Good" sample file.
edDV
Yes you are correct, i want to support MPEG 2 (part 2) Main Profile, Main Level. plus additional restrictions imposed on DVD (such as framerate, audio, aspect ratio, etc.)
With that in mind, i have a question for you: Can a maker of an MPEG2 codec decide only to support Simple Profile but still call it an MPEG2 codec even though it won't support interlacing for instance?
I'm still a bit confused why one codec would make a file play completely different than another if they are following a standard. Naturally, you can't control every codec maker to perfectly adhere to the standard, unless there's some "Certified" codecs by MPEG. Are there? [b]Edit]/b] Since MPEG only standardize the bitstream and its interpretation, then the end result could be QUITE different between codecs? no?
Thanks again all, you guys rock.
Closed Thread
Results 31 to 40 of 40
Originally Posted by Popoi
It all depends on what you are doing in your applcation. I don't understand your application. If you control the input (e.g. Video Games) then you can restrict supported video or audio formats. Read your licensing terms.
If you call it a MPeg2 player then you need to support all formats in order to fullfill the MPeg2 standard requirements and quite probably the license. I haven't been envolved with writing a MPeg2 DVD player so I don't know.
Originally Posted by PopoiRecommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
Originally Posted by PopoiWant my help? Ask here! (not via PM!)
I'm glad you're able to learn from reading and asking questions, but i don't understand why i'm not allowed to ask questions if you are? You baffle me. I'm not looking for you or anyone here to solve my problems by giving a precanned solve-all answer as you seem to imply.
My question was simple: What's the middle ground for encoding-decoding between Mac and PC. It was elegantly and effectively answered by Cornucopia.
My Problem is solved. Thread closed, go back under the bridge.
thanks all who provided with insight and knowledge (i'll promise to forget it so smurflord won't be offended)
There isn't a middle ground. Your questions come across as non-sense. All of the posts to date have tried to explain this very fact.
MPEG-2 is MPEG-2. I work with both Mac and PC. There are only a few decoders out there, software and hardware. It doesn't matter if you have Mac, PC .... whatever ..... it'll look relatively the same.Want my help? Ask here! (not via PM!)
You can lead them to water ...
but you can't make them say "decoder"Recommends: Kiva.org - Loans that change lives.
Then it means your computers have problems.
https://www.videohelp.com/forum/viewtopic.php?p=1396325#1396325
Capturing VHS to Mac via Panasonic AG-1980 and ATI 650 USB Mac
By Stu187 in forum Capturing and VCRReplies: 3Last Post: 15th Aug 2010, 05:45 -
serious codec issues mac?
By aceswild in forum MacReplies: 10Last Post: 20th Nov 2009, 13:45 -
serious quicktime issue, basic MOV codec corrupt? mac
By aceswild in forum Video ConversionReplies: 1Last Post: 18th Nov 2009, 15:46 -
K-Lite Codec for mac
By pixel zombie in forum MacReplies: 3Last Post: 9th Jun 2009, 03:25 -
How to get avi codec for mac????
By balonglong78 in forum EditingReplies: 14Last Post: 9th Feb 2009, 19:13
