  1. I have some questions, Iam a rookie in this so I need your help:
    -I read that to be VCD 2.0(PAL) the mpg must be 352x288, but what about 16:9?
    Can I make a 352x216 and still be playable as a VCD compatible in DVD??
    -After making the mpg, I burn it with VCD Easy. I have the VCD, unfortunately I dont have a DVD player so
    I dont know if it is playable in DVDs. I played in my computer with Radlight.
    After burning the VCD with VCDeasy, Do i need to make an autorun?? or it will be just ready to be played on Standalones dvd players?
    -And my last question, Is possible to add subtitles to VCDs. I know that I can add subs .ssa, but its possinble for that subtitles to be switchables in standalones dvd players? If its possible, in wich folders I must put the archive??
    Feb 2001
    Palmdale, CA
    check out kaills dvd rip guide in the link section of this site, 16:9 is no problem you just select the format when you encode. here is the site, I have tried most guides here for vcd and his has given me the best results for over a year.
    http://www.dvdripguides.com
