What would cause a movie to become "stretched" out. I have a XVID movie that is 2 files, it is 608x336, NTSC (film). They look fine if I just view them on my DVD player (I have a divx dvd player), but if i want to create a DVD so I can bring them and watch them elsewhere the video gets "stretched" - meaning in the beginning when it is showing the credits they are not in full view half of them are cut.
I am running version 2.0
Hope this makes sense and someone will be able to help me.
Thanks.
Results 1 to 9 of 9
Have a look at https://www.videohelp.com/forum/viewtopic.php?t=282396
Are your TV & DVD Player NTSC by default?SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Yes my tv and dvd player are ntsc by default. I don't think I have had problems in the past playing PAL movies though? Just seems to be this one.
I can maybe try another and see what happens. Any other suggestions? -
what about when you play the dvd on the PC?
I will have to check when I get home. What are the drawbacks (besides taking longer) is the convert PAL -> NTSC option? Is the degradation in quality that noticeable?
Thanks. -
You said your sources were NTSC->Film, therefore PAL to NTSC is not relevent here.
Yes you are right, I was confused because it has the same aspect ratio of another file I had that is PAL (608x336).
Well it will still be interesting to see how it plays on the PC... Can you view it on other players too to see if we can isolate the problem?
Vegas 8 and still images - always stretched?
By Foxhack in forum EditingReplies: 0Last Post: 13th Sep 2010, 20:11 -
1440x1080 stretched at 1920x1080
By catracho2009 in forum Authoring (Blu-ray)Replies: 21Last Post: 6th Aug 2010, 19:07 -
Final Cut - HD looks stretched
By cupaT in forum MacReplies: 11Last Post: 26th May 2010, 23:16 -
By cupaT in forum Video ConversionReplies: 9Last Post: 26th May 2010, 23:01 -
My 4:3 gets stretched like widescreen
By notbillymays in forum Newbie / General discussionsReplies: 6Last Post: 21st Dec 2009, 08:31
