I have used the program and works very fine. It gives a 7800 kbps bitrate, and I wonder if it will be possible to obtain a higher one. For example I have converted a 7701086 transport stream into dvd. It has a good quality but I suposse that it could be another way to making a DVD with a higher bitrate thinking in it burning into a 8Gb DVD.
There were a lot of transport stream files and I join them with HDTVtoMPEG2. With this program you can also obtain a MPEG2 file with the same bitrate than the original ts. I tried to create a DVD using tmpgencDVDauthor but the program doesnt like the aspect ratio and the little conversions that I tried with tmpgenc to change it gives me very bad results and the audio without sync. I also tried with authordvdgui and this programs dont like the size/aspect of the mpeg2 (too big/too high I suposse). I also tried with Ifoedit authoring options and it doesn´t work.
Well, any ideas will be apreciatted.
HDTV2DVD 0.4 Vista
By CathyT in forum Authoring (DVD)Replies: 2Last Post: 28th Dec 2009, 13:01 -
HDTV2DVD does not load up TS-file
By feilofix in forum Authoring (DVD)Replies: 2Last Post: 12th Nov 2008, 14:25 -
New Tool: HDTV2DVD
By ChrissyBoy in forum SVCD2DVD & VOB2MPGReplies: 270Last Post: 2nd Jul 2008, 23:05 -
HDTV2DVD - .TS wont load
By NotSoEasy in forum SVCD2DVD & VOB2MPGReplies: 11Last Post: 15th Mar 2008, 20:09 -
How to load .ts file into HDTV2DVD?
By JR.S in forum Newbie / General discussionsReplies: 2Last Post: 15th Nov 2007, 02:59
