topic
or
DivXtoDVD if you want a dvd.
tmpgenc may not work that good, be sure to try increase the directshow property
winavi
cucusoft
Install the haali splitter if you can't play/convert the mp4. And remember that mp4 is a container format so you might need the video codec installed also...I use ffdshow to decode most stuff. -
You could also try SUPER it's free and works pretty well. It's just a frontend for several other freeware encoders, but works really well.
Melde Melda Vessė
Eruanna ar Eruntano Melda Eruntanohini
"May your days be bright and contact with stupid people limited."
Is there a program that watches a folder and auto converts mkvs?
By chris_huh in forum Video ConversionReplies: 2Last Post: 27th Sep 2011, 16:37 -
Can't convert one mp4 file, but another from same download converts just fine.
By ibzomie in forum Video ConversionReplies: 1Last Post: 8th Feb 2010, 18:53 -
Need to find a program that converts to MPEG-2 Transport Stream
By rprice806 in forum Video ConversionReplies: 2Last Post: 20th Oct 2009, 12:10 -
mac program that converts mkv?
By furida in forum MacReplies: 4Last Post: 17th Aug 2009, 16:59 -
a new program that converts videos to 16:9 without screwing up the picture
By Michael1T in forum Video Streaming DownloadingReplies: 34Last Post: 23rd Jul 2009, 06:19
