here is the Thing:
I've got a audio track for a video that's in mp3 format. But when I use the Ulead DVD Workshop 2 to author it leaves the last 5 minutes or so wihout audio. If convert to wav the the program does NOT compress it and I usually end up with 2 Gigs of audio only. The format that Ulead uses is MPA. How can I go from MP3 to MPA?
Thanks for any help
Results 1 to 9 of 9
I've tried converting to mp2 using TMPeg but the Workshop does not recognize de .mp2 extension.
I'm going to try BeSweet and that other program.
Thanks -
What audio format(s) do Workshop like?
If it doesn't like mp2, but mpa, just rename the mp2 to mpa.
/Mats -
I did and it worked using ffwhatchimacallit.
Thanks for everything, problem solved -
Whenever I try to use besweet It asks me for some different .exe for each one of the conversions. But thanks anyway the other program did work.
bye
How to convert WAV/MPA/MP3 audio to AC3(DD) using Besweet
By Baldrick in forum User guidesReplies: 89Last Post: 11th Aug 2012, 16:14 -
How to convert WAV/MPA/MP3 to AC3 6 channels?
By katalogas in forum AudioReplies: 8Last Post: 16th Feb 2010, 14:12 -
jvc dr-mh30s problema hd
By senateur in forum DVD & Blu-ray RecordersReplies: 0Last Post: 11th Nov 2009, 06:22 -
Trouble converting AVI(divx)+MP3 to FLV+MP3
By BLboy in forum Video ConversionReplies: 7Last Post: 21st Jul 2009, 04:36 -
Looking for simple software that will convert mp2 mpa to mp3
By jimdagys in forum AudioReplies: 23Last Post: 20th May 2008, 08:26
