Can any one tell me how to configure macromagic to switch dr divx on so i can set a timer recording.
The Righteous Shall Inherit The Earth
https://www.videohelp.com/forum/userguides/149967.php
This guide is actually for scenalyzerlive, but essentially the events it uses are probably the same or similar, so you should be able to work it out.If in doubt, Google it. -
No problem.
I seem to recall that the help documentation is pretty good with macro magic though, no ?If in doubt, Google it.
DVDPlayer B.L.E. setting?
By wiseant in forum DVD & Blu-ray PlayersReplies: 1Last Post: 23rd Jan 2009, 12:52 -
PS3 HD setting?
By duketuring in forum ffmpegX general discussionReplies: 0Last Post: 15th Oct 2008, 10:02 -
I need a little help setting up this card!!!
By mshaw86 in forum Capturing and VCRReplies: 0Last Post: 12th Oct 2008, 23:31 -
which project setting?
By wingfan in forum Newbie / General discussionsReplies: 2Last Post: 30th Aug 2008, 09:36 -
which setting should i use
By fruitpassion in forum Video ConversionReplies: 4Last Post: 23rd Aug 2007, 19:58
